FP6 flip case and display
Hello, my brand new fp6 android 16 does not switch on/off the display by opening/closing the flip case, although enabled in settings. Is this an issue, or have I check out further settings (camera or so)?
Greetings Karl
Solved!
The flip-case switch works with magnetic hal-sensors. My case is trashware, w.o. magnets
Karl
Just two ideas in this context.
There is the WaveUp app that uses the proximity sensor for waking/putting to sleep the display, usually with your fingertip. Perhaps it works with the flip case cover, too?
If you would like to not having to resort to the power button all the time, you can set the FP6 to allow you to wake up the display with a simple double tap. /e/OS (and probably other CustomROMs, too) also allows to put the display to sleep with a double tap in the status bar.
P.S.: A belated welcome to the Community! :+1:
