I have a removable eUICC card (ChillaxSIM) in the SIM slot of my FP5, alongside the internal eSIM. Since some point in August, the SIM slot no longer does anything at all with that card.
The symptom, precisely: it is not “no network” — the modem never even searches.
Phone 0: registrationState = NOT_REG_OR_SEARCHING
rejectCause = 0 (no rejection, ever)
mCellInfo = [] (no cell measurements at all)
mSimState[0] = LOADED (card is read fine)
Note NOT_REG_OR_SEARCHING, not NOT_REG_SEARCHING. The stack is idle, not searching.
What rules out the obvious causes:
- Same slot, ordinary SIM (an old expired one): searches, attaches, gets
rejectCause=2. Slot hardware is fine. - Same slot, a different removable eUICC (eSTKme): searches, attaches, gets
rejectCause=15. - Same card, same profile, in a Fairphone 4 (Android 15, DSDS, internal eSIM also active): full service, voice and data, both slots simultaneously.
- Also works immediately in a Samsung Galaxy.
Checked and excluded on the FP5: modem enabled for the slot, radio power on, no radio-power-off reasons, automatic network selection, allowed network types identical to the working slot, carrier config equivalent between slots, isMultiSimSupported = 0 (allowed), DSDS configured, mobile data and roaming on. Telephony database cleared twice, mobile network settings reset, both LPA services (com.google.android.euicc, com.qualcomm.qti.lpa) disabled and re-enabled, several reboots.
isEmbedded correlated at first but turned out to be irrelevant — on the FP4 the same card is flagged isEmbedded=1 and works, and the flag flips back and forth on both devices during updateEmbeddedSubscriptions runs.
The one thing I cannot inspect is the modem side. isModemEnabledForSlot(0) returns 0 whenever this card is present and recognised, and 1 with any other card — but it looks like a consequence, not a cause.
Timeline: the card demonstrably worked on VT2Y in early August (the slot was transmitting; I have network rejections from a foreign operator to prove it). The phone is now on VT31, and it has not worked since.
My question: has anyone seen an FP5 stop driving the SIM slot when the inserted card presents itself as a eUICC? And is VT31 a plausible suspect, or should I be looking elsewhere?
Thank You all, best regards.
