I’ve recently switched to e/Os on my new Fairphone 5 however my banking app doesn’t work so I have to move back to Fairphone OS.
I downloaded the setup package from https://support.fairphone.com/hc/en-us/articles/18896094650513-Manually-install-Android-OS-on-your-Fairphone but when running the shell script on Linux (PopOs) it stops after detecting my phone without any errors:
*** Fairphone 5 flashing script ***
INFO: The procedure will start soon. Please wait…
INFO: The package type is “user-factory”
INFO: You are using a Linux distribution.INFO: Validating the integrity of the package.
This might take a while. Please wait…
INFO: Validation complete.
WARNING: Flashing this image wipes all user data and settings on the phone.
It will also remove the Google factory reset protection.
Are you sure you want to continue?
Type “Yes” (case sensitive) and press enter to continue: Yes
INFO: Looking for connected device(s)…
INFO: One Fairphone 5 in fastboot mode found (serial number: xxxxx).
Is there perhaps a guide on how to do this manually through adb or fastboot?
