FP4 problems with Signal voice messages
For the past 2 weeks, I’ve been having issues with my FP4 when using Signal—specifically, sending voice messages. It now takes a few minutes (!) instead of just a few seconds (which is how it used to be). WiFi is not the problem (other phones/laptop no issues). I also have Signal installed on my laptop, and there, voice messages are still received almost instantly. When using WhatsApp on the FP4, sending voice messages works quickly. So this problem only occurs on my FP4 and only with Signal.
I’ve updated the operating system (Android 15), updated the Signal app, cleared Signal’s cache, and restarted my FP4… none of it helped.
  • Does anyone else recognize this issue?
  • Or does anyone have any idea what might be causing this/how I can solve it?
I’m having the same problem with my Fairphone 4 running e/OS. And I’m pretty annoyed by it. I’ve tried the same things also, but nothing worked for me either.
Thanks for your reaction!
So we have the same problem, but with different operating systems…
Hmmm. I’m not a Signal user, but the common factor is the Signal app on Android. Are there any other reports from Signal users on other Android platforms, e.g. on the Google Play store or (?) F-droid app store?
This may not be the answer, but at least worth checking out.
Thanks for your reply! I just checked the comments on the Signal app in the Google Play store, but didn’t find any similar experiences in the last month.
I installed my “Signal” app from the F-Droid Store.
Today, I kind of get the impression that it’s running a little faster again after the 8.31.2 update. It’s still not as fast as it was two weeks ago, but at least it’s an improvement.
Have you noticed any changes? Has it gotten a little faster for you, too?
(Translated with DeepL)
Which version of Android and Signal do you have installed?
I’m running Android 16 with Signal 8.31.2, both on the e/OS operating system.
I have Android 15 (no e/OS operating system) and Signal 8.31.2 and still have the problem. After updating Signal to 8.31.2 it didn’t seem to send the voice messages faster.
Is anyone else having this problem so we can compare notes?
I’ve already sent several messages today, and things really do seem to be working better for me starting today, even though I haven’t changed anything.
I hope it stays this way.
Unfortunately, I have to correct myself.
This afternoon between 2 and 4 p.m., all the audio files loaded quickly again. Now, at 6 p.m., it’s just as slow as it has been for the past few days.
Could this all just be due to an overloaded server?
Using FP4 with e/OS/ 4.3.1
No problem here with Signal Voice taking too long
( simply FYI )
Hi there!
Just found this entry, looks like what you describe, right?
I’m on the mentioned 8.32 (beta testing), don’t remember having had slow voice messages recently.
Edit: And several reports the speed improved drastically: Beta feedback for the upcoming Android 8.32 release - #7 by fm-sys - Android Beta Feedback - Signal Community
So it should only be a few days wait until 8.32 is released and you update
Thanks for your comment! I will join the beta testing for Signal too, let’s see if this helps :slight_smile:
Thanks for the heads-up—I’ll wait for the update, too. My last 5-minute audio file just took 7 minutes to arrive.
Thanks a lot @janweiss . Joining the beta testing and after that updating to Signal 8.32, indeed solved my problem with the slow voice messages :smiley: :smiley: .
