I’ve recently added an eSIM from my company provider to my already used normal SIM. In the beginning everything seems to work fine, but after going into roaming (provider for eSIM Vodafone.de) because I traveled to Austria for holiday I noticed that the eSIM does not connect anymore. I wanted to use the VF Sim only for data, the other for calls/sms. When switching back to the Telekom sim, everything works fine, when putting the VF Sim on data, both sims disconnect, no calls or internet possible.
I thought returning to Germany would fix it and there is just something up with the roaming but that was not the case, the issue is still persistent. I’m on patch a.140
Does anyone else has these problems?
