Thanks.
I am looking for a way to edit og moderate the settings more than just switch it on or off.
Any ideas?
no
I fall you want to do is make calls and save battery
- Dim the screen#
- Use black and white âBedtime modeâ
- Uninstall/disable lots of apps
or are you just looking for a quiock switch between saving and full on usage.
Exactly. A way to quickly switch from extreme powersaving mode to normal mode would be great.
Youâll have to wait for Android 12
This is an Android 12 feature, right? I have this on my Pixel 3 since Android 12, not on Android 11 (like on my FP4). But I suppose you donât use the vanilla FP ROM? If not then please share that information, then people know what to expect. Android 11 doesnât have an extreme power saver by default.
I donât think this is a general Android 12 feature, itâs at least not in Calyx A12
I hope itâs not Pixel exclusive
Iode 2.4, A11-> available
Iode 3.0, A12L-> not available
