Many thanks. Yes it is running fine (so far) and it booted normally.
One last question: The rooting process will wipe my data?
PS: If one of you guys ever visit Hamburg - ping me, now I owe you a dinner + drinks for this support!
Usually not, because your data is stored on a seperate parition. Modifying the boot partition leaves the data partition untouched. But it is always a good idea to have a working backup!
Thanks, trying to patch you .zip tells me that something failed. Then I realized I need the boot.img. but where do I find yours? it’s neither the .zip and the recovery.img from you right?
You can use a tool like payload-dumper-go to extraxt the partitions (including boot
) from the files in lineage-19.1-20220511-UNOFFICIAL-FP4.zip
I’ve uploaded you a patched boot.img
, just install the Magisk app and follow the usual instructions:
Thanks! Would you mind to explain the steps, how to run the tool. The read me does not explain. I know how to clone and that I need to install Go.
Sure You can download prebuilt binaries for your architecture from the github releases, no need to install Go. If you are on an Arch based distro, it’s also in the AUR (but then what isn’t ).
Extract lineage-19.1-20220511-UNOFFICIAL-FP4.zip
first, you’ll find the payload.bin
file in there we’re interested in.
If you’ve downloaded payload-dumper-go
manually, just extract, it open your terminal where you extracted it to and run it with ./payload-dumper-go path/to/payload.bin
and it will create an folder extracted_$date_$time
in the current directory.
If you struggle with the payload-dumper I’d suggest you go with the first suggestion from @hirnsushi as it doesn’t require you to run any kind of tool:
Install Magisk app on your device
Download the LOS patched boot.img
Follow these instructions:
Just to mention an alternative method I successfully used to have boot.img, is to (one-time-) boot to TWRP and backup the boot partition on the external SD card.
Internal memory is not currently available with TWRP-for-FP4 because of decryption incompatibilities, but boot partition is not encrypted so can be backed up
Is the way back to original also possible?
Back to original FPOS? → https://support.fairphone.com/hc/en-us/articles/4405858261777
Back to an unrooted phone? Just press Uninstall Magisk in the Magisk app.
I updated my description with you points @hirnsushi
However, I delete the last point fastboot erase metadata
. After that the LOS was corrupted I will not do it with the new attempt. So is it badly required?
Would be great if you give my summary another review. FP4 and LineageOS - #255 by echo1
Cheers
CC: @Aaanze @mmustermann
That sounds about correct
Did you manage to successfully root your device ?
Yes - AFWall+, XPrivacy, AdAway work like a charme. After 7 years a new phone with LineageOS <3 - another 7 and more on the road
I owe you folks, let me know how if applicable. My offer is still valid!
New build with security patches of June is up.
363cc765fd069e149e8f618b98796c79a1b014ab13c95bfad7fa04cfd1ad846f recovery-19.1-20220611-UNOFFICIAL-FP4.img
8a7f04657b5e52c054fbe3b093ffaf8140b03eb5c4786005bcd3675697b5991f lineage-19.1-20220611-UNOFFICIAL-FP4.zip
@echo1
Please let us know if your root survives the update.
Install went great, no root also installed MindTheGApps and that worked fine. Just had to make sure I was in Lineageos Recovery. Nothing wrong so far.
Everything works? And if not there is a way back right? I want to try…
I really want to try but step 4 scares me a little. Is there no way back to stock os? Or I don’t understand it well?
It was not possible at the time of writing those instructions (I guess), now it’s definitively possible to revert to stock OS
General advice if you try other OS: just be careful with relocking bootloader (don’t relock it OR check before that get_unlock_ability = 1 )
I had issues reverting to stock, but using a super old adb/fastboot utility was able to wipe and reinstall stock. If you don’t know what you’re doing I’d advice against it, as it seems pretty easy to brick the Fairphone 4, from my personal experience.
@mmustermann I assume flashing the new build is the same procedure without factory reset (to save personal data)? Or is there something I need to consider?
So basically:
→ Flash Lineage recovery & Reboot to recovery
→ adb sideload
→ Rooting process again
