FP3 with /e/OS - Crash, Black Screen won't start until plugged in restarts with same battery %
Hey!
I’ve installed the /e/OS on my FP3 everything works fine however 2 days ago my phone crashed and had a black screen. Tried to restart, nothing would happen for a couple of seconds. Plugged it in and it restarted and had the same battery level as before. Same happened a few moments ago again.
I asked in the /e/ community and I’ve been told that it sounds like a hardware issue.
I have the FP3 since March and it sometimes crashed randomly (not often but i happened) with the stock OS.
Is the battery maybe wrong calibrated?
Any ideas?
Cheers
Hi there and welcome to the community forum!
Did you check the #blackscreenguide? (it’s for FP2 but should globally work for FP3 as well)
Did you check the #batteryguide?
To calibrate it, you can do a #dic:kickstart.
Hey, thank you very much!
I did the kickstart twice but that didn’t change anything. And I think I used the wrong wording - it is not a black screen. The whole thing crashes and I have to push the power button for quite some time.
I also discovered that I don’t have to plug it in for it to reboot.
Maybe an App is crashing something. I have to read myself into how crash reporting and logs work on android and maybe find sth there. I’ll post here as soon as I find sth.
Cheers
This might help:
