I changed my display, because it was broken. Now my FP3 looks good but the charging process stops radomly, and I need to replug the USB, than it charges for a while, and stops again.
Does anyone have an idea, what the cause could be, the battery, the USB jack?
Only suggest reassembling didn’t get some good contacts, so maybe repeat the disassembly / reassemble task and clean the contacts. Also check the USB port for debris, use a magnifying glass and ensure it is clean with bright contacts and of course try a few different chargers and cables etc.
