I just bought me a FP3+. When I unpacked it to set it up I got a bit confused. The manual shows that I have to remove the protectiv bumper (which I know from a friends FP3). But there is none.
Can someone please tell me if there isn’t such a case for FP3+ or if its a mistake of the shop I bought it (not the FP shop, because its temporarely not available).
The black bumper was only included with the FP3, the FP3+ came without the bumper because Fairphone tested the FP3+ and found its housing more robust than the FP3’s. So they found that it was not necessary to add the bumper to the FP3+.
I think the manual that you mentioned is the same for the FP3 and the FP3+ and actually has an “FP3” marking where the bumper removal is described.
A protective cover is nonetheless a good idea. But at €40,- Fairphone delivers a plastic case that after some time stretches so much the phone will fall out when you drop it.
