Is it possible to use FP3 with a CTIA headset to record sound? My headset works perfectly with my laptop but with FP3 the mic is not working, only the headphones …
CTIA sounds good.
https://support.fairphone.com/hc/en-us/articles/360032264192
Same problem here. I suspect it might be a physical problem with connector not adjusting completely (as per Headset mic not working).
I’ll try other headphones and see if that helps…
Your link is not accessible anymore. I guess it’s the same they now put in https://support.fairphone.com/hc/en-us/articles/360047959012
I have the same issue with the microphone adapter for the Shure SE215. It neither works on my mum’s FP3, so I’m confident that it is a general problem of the phone model…
