Hi all
Since I received my FP3, I have noticed that I did not have vibration during incoming calls.
I have checked that vibration is enabed in the Parameter menu and it is enabled.
Recently I have dowloaded and installed #dic:checkup and made all the tests
-everything is OK except the vibration
When I launch the test, I am supposed to feel a vibration ? And the test is running but I did not feel any vibration
Do you think it is a harware problem or have I forgotten something ?
gee
October 15, 2019, 12:38pm
#2
Did your phone ever vibrate for anyting? If I remember correctly, it was set to do some low level vibrating on touch when I first got it
Edit: I just tried the vibration test with the checkup app and my phone did indeed vibrate.
No it has never vibrated !
You said “If I remember correctly, it was set to do some low level vibrating on touch when I first got it”
I s there a way to increase the level of vibration ?
gee
October 15, 2019, 1:51pm
#4
That setting is in Sound->Advanced->Touch vibration
But it is just an on/off switch
Very strange !
Now the FP3 is vibrating !!!
What have I done ? I do not know : I have not changed anything in the parameters and not rebooted the phone.
The only thing I have made is to install Avast ! Some malware was blocking the vibrator ?
Sorry for the trouble !
I do not know how to put “Solved” on the discussion but it is solved ( for the moment )
gee
October 15, 2019, 2:16pm
#6
Desiderius77:
No problem. Glad it’s working now!
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
