After installing /e/OS on my Fairphone 3 I noticed that it is very laggy when unplugged. Choosing High Performance in the Battery settings only drains the battery more and only helps until the next reboot.
After a few minutes of research I found a similar forum post that said that the latest update fixed it. However this was back in the “Android 9 days” and the issue is there (again?).
Thank you. The problem is both when the phone is connected and deconnected.
I’ve just contacted the vendor Esolutions. I very much hope they know a way to fix this. As soon as I have a solution I will post it here.
Hi again, the issue will be fixed with /e/ OS 0.18 (the next version that will come out soon). The team included a custom perf config (or something ??) and the issue is fixed. For reference, see:
(it still seems laggy on the video but thats because of screen recording, which is never smooth)
