stock firmware link to A.0101 (Nov 2019) - for anyone who needs it
https://www.androidfilehost.com/?fid=4349826312261713361
Filename: Fairphone_FP3_8901.2.A.0101.20191115_11150009_user-release-keys.zip
md5sum: 051eb5375d1412f77c9b83c51e1c6e42
sha256sum: 5384b8bc71d4dd284f21626b59004e5b2b5cebf8ce855bca7852b2be086a4ac4
Independent Verification: You can cross check against vendor check sums
using payload.bin from https://android.googleapis.com/packages/ota-api/fairphone_fp3_fp3/eab40c208c6bd6899b51e7103822972d7a40336c.zip and https://github.com/CorvusCorax/payload_dumper in --diff mode (will ignore trailing zero bytes).
Applying the payload.bin will get you to A.0105. Furher applying https://android.googleapis.com/packages/ota-api/fairphone_fp3_fp3/996d9c3cd83bf55bcbf4674a7074885e2d66e0f8.zip payload bin will get you to A.0110
$ sha256sum *.img
845924ee31a3ad8ca86e122299679cc7d2cd192b64060b9e4009a784f6889056 aboot.img
c8695bc30189a80ca0f70fda81d34d821c9215420c0c22226d774a2b700f37cf boot.img
e67326e2050a9174a9d437e70e4954f97385ff22fd8e40c51115c582ffa7c13d cmnlib64.img
be941fd8a054104ed8fb2ebfefa00b742d379f4e784c9d5f3a1638e4e7329355 cmnlib.img
c5e571383664f1704a033a4055e4dfffaa1d60d07fe15e7616590d129dda939a devcfg.img
feaa15a42cb63bc81fffe93e79eaa9262c8c1818abe40f43ba713c5184ac5839 dsp.img
cade61b50b2ba8a3c866b8ea928162bafe8c33386d712a9a78cf0857b1ef6833 dtbo.img
1982e8cec6f9fe3984da7d1184346e1a437013e47be2bf5fcc72b91e6e24efe4 keymaster.img
3fdd919985501069641d59b16f7034609018186b2f33a6850e7f113a0fd0383e lksecapp.img
c47821e639220f11a04e6d03dc2f6e67fe73dcb8738ffd1968462ea98a21c7d6 mdtp.img
0933af7ceadc3cdda1e2a6ca15f8b354ab38aa15dcebb74019c822584562e84b modem.img
4e097e334c1231bc1d967fd8256211ef7c7d055b5f0defbd69306868df8857d9 product.img
95994f93282b372173057b045f9be0f29262ca982f787e331bb16678409a0540 rpm.img
8139a8f922287f0a6e6da6c627503bf72910f591429a815d918ed4dffdf966eb sbl1.img
6ac7ba7e3bd58f4c80b388a3812bafa78f90e19b6474b7a36e913cf0b2437cca system.img
e9ce4855657b7ecf63b777a644a6ce1bde0da616826ae3e1bd3e18f1334fe4f3 tz.img
3248b79a1f79a4648cdad89398a41f8d8ac6ec11e6b7d9ca235b659d2839ea9c vbmeta.img
c95a77493d4a79a303ce388bde11c172a64642f9e12dd2546a9f4026e64aa5cd vendor.img
verification:
$ python payload_dumper.py --diff payload.bin
Processing modem partition... Checking original Sha256, should be CTOvfOrcPN2h4qbKFfizVKs4qhXc67dAGcgiWEVi6Es=
... passed...
extracting... truncating... Checking new Sha256, should be uHW4LbgFtXmxV1+teceezEVABCib10a2i3B2gW75+HY=
... passed... done
Processing sbl1 partition... Checking original Sha256, should be kar6XUqbymOV72Qh/oFfe9mUupFuPu75/WabRFQm1D0=
... passed...
extracting... truncating... Checking new Sha256, should be 3iRULfan90ZPWy2QHzeaIywOUEqkuyYgBWKyf9Hk6PU=
... passed... done
Processing rpm partition... Checking original Sha256, should be EwlUjVBzt+j66Mg3/KT+nURNTxjfRSCP0cKE6mJ+jRQ=
... passed...
extracting... truncating... Checking new Sha256, should be kikeLNG4xKlPqaQqzPcj3JQyfwiwen9nj+S1MgcpjEM=
... passed... done
Processing tz partition... Checking original Sha256, should be 7w0fA6NRXHIuw0m2HE7A2q4IeQDjm19oxtOc6sq3ou8=
... passed...
extracting... truncating... Checking new Sha256, should be qXgGb2NgGOUVRV+CxVvB8kX0EpI62133/4ytrQZg/X8=
... passed... done
Processing devcfg partition... Checking original Sha256, should be a5OHX+pL9/cL11bqSNz41MQp6HuQBJ3ZJGBZIGAbdQg=
... passed...
extracting... truncating... Checking new Sha256, should be T35U136bWdVNyZuJcvQTzJrj1CgmTMCO5kLFYvIAK/0=
... passed... done
Processing dsp partition... Checking original Sha256, should be /qoVpCy2O8gf/+k+eeqpJiyMGBir5A9DunE8UYSsWDk=
... passed...
extracting... truncating... Checking new Sha256, should be /qoVpCy2O8gf/+k+eeqpJiyMGBir5A9DunE8UYSsWDk=
... passed... done
Processing aboot partition... Checking original Sha256, should be wKA7kN0CoGNQcfbg7Bpn+DydHQlqmSnWtrParETMhII=
... passed...
extracting... truncating... Checking new Sha256, should be KXmQci8cU5P9IUKXol2o4qw54kUE6y4mzB4TFL6/Pww=
... passed... done
Processing dtbo partition... Checking original Sha256, should be yt5htQsrqKPIZrjqkoFiuv6MMzhtcSqaeM8IV7HvaDM=
... passed...
extracting... truncating... Checking new Sha256, should be kEUcBPYvu+pz5cUCb7qx9KmLjkeGlqpWlvtKHID7itw=
... passed... done
Processing vbmeta partition... Checking original Sha256, should be mTSdCq7aC8ZIqODfX4Z02wvTqs6E75OSY7jw97vxARo=
... passed...
extracting... truncating... Checking new Sha256, should be SuaZ/8GipVzd68nhGlpPPFDJXgQNNeMc5NYMYfOW//c=
... passed... done
Processing boot partition... Checking original Sha256, should be yGlbwwGJqAyg9w/agdNNghySFUIMDCIibXdKK3APN88=
... passed...
extracting... truncating... Checking new Sha256, should be /I7hvKKxvGXORU+CCdH2epRBtbdoySCkpxJrv80xfgo=
... passed... done
Processing system partition... Checking original Sha256, should be ase6fjvVj0yAs4ijgSuvp4+Q4ZtkdLejbpE88LJDfMo=
... passed...
extracting... truncating... Checking new Sha256, should be Liw8mKN2aLsNgVHs/tu5ziCLclop6dynwnxFSqg1H7U=
... passed... done
Processing vendor partition... Checking original Sha256, should be yVp3ST1KeaMDzjiL3hHBcqZGQvnhLdJUap9AJuZKpc0=
... passed...
extracting... truncating... Checking new Sha256, should be PpYt1c0pixRKlOlQYBmbNO1ti1aBCBptkvtqACiDDx4=
... passed... done
Processing mdtp partition... Checking original Sha256, should be 3UmJGHRUbFJowuS3vjyVsTd33YzQpt/ER9vY/Fkn4rk=
... passed...
extracting... truncating... Checking new Sha256, should be D9f4qXZyV2tkFGfhr30tZ6Aj6ErFTQSry8Ni6OGybwI=
... passed... done
Processing lksecapp partition... Checking original Sha256, should be OS0HWbkaczBKrVZ+7difoybiOeHzZInqO7vHL5hXHB4=
... passed...
extracting... truncating... Checking new Sha256, should be 4C0eklWxwA5qnPYXWMWBcluzIrqHv5CnMdnINYDMZWM=
... passed... done
Processing cmnlib partition... Checking original Sha256, should be m/VLgHlSQt/NukkbIPFpn0lqUWB3EzLYnLMYK8epIRg=
... passed...
extracting... truncating... Checking new Sha256, should be JZxlbOinSAO23eysX0R64jpHv/xluM+BOSssri7+BiI=
... passed... done
Processing cmnlib64 partition... Checking original Sha256, should be 4y8JsNsSKktjJxJq/iWEzy0Inrtvi4V8gLJTifw4mGo=
... passed...
extracting... truncating... Checking new Sha256, should be +VrbC5/Ccalf+WQ6TpcncvLC4tWF2+1qwyRm3idU+5U=
... passed... done
Processing keymaster partition... Checking original Sha256, should be dXiXiRgYC5pFJV8EqSnhoeBajQcl45yhufrFrXm1dRw=
... passed...
extracting... truncating... Checking new Sha256, should be Vd6R61DSpG34I+nHkogdpmx8krdbAlUzZkuIS2JD+2I=
... passed... done
Processing product partition... Checking original Sha256, should be Tgl+M0wSMbwdln/YJWIR73x9BVtfDe+9aTBoaN+IV9k=
... passed...
extracting... truncating... Checking new Sha256, should be 0I32cRejEBKI2z60Ht03+8Jd4+nNstHlzT8//VFzEk0=
... passed... done
