FP3 became laggy, not setting default apps
Hi there, I’ve a FP3 since May of 2020.
Lately I noticed that it became a lot more laggy and has some issue setting some default app (I’m using a different launcher for example).
I’ve done a factory reset like a month ago, so this seems odd.
Should I be worried? Can I check some things to discover why it is acting like that?
Thank you.
Regarding launcher see here
https://forum.fairphone.com/t/keeps-asking-which-launcher-to-use/87654/24
Else how full is your storage?
Thank you for the quick response.
The launcher seems to be in order.
The memory is at 65%
