after installing Lineage 18.1 with MicroG at some point my phone was crashing all the time, oftentimes being stuck in bootloops.
I used the lineage recovery to try from anew, after which it functioned better especially, I think, as I turned off any running in the background options for certain apps.
Then however the problem returned. Not exactly as bad, but quite so. Without having a real reason I since use the phone with both SIM cards detached, and more or less it looks to cope much better. The downside of it being, that I can’t do phonecalls or use mobile data anymore.
I wanted to ask if this sounds familiar anyone and if anybody knows the reason or how to fix it-
Is the FP2 just too old for 18.1?
Recently I switched off some background messages which seems to also have helped. Currently the phone seems to be a bit less prone to crash. However I only use it occasionally.
Isn’t there anybody with similar experiences with FP2 and Lineage 18.1 with MicroG? I talked to a friend lately who had very much the same problems.
I’m wondering whether this will improve with a new update of 18.1.
That said I think I saw Lineage 19. Could it possibly have less problems like this even if it’s newer and the phone grows older with each new version?
