✏ FP2 : USB device compatibility
With updated FairphoneOS 1.2.8:
  • HiFime DIY 9018D works perfectly, even with 250ohm headset (Beyerdynamics DT900 pro)
\o/
(still nothing with AudioQuest DragonFly 1.2)
Thanks @siltaar !
Could you possibly update the wiki with your findings ?
The changelog doesn"t mention anything about usb, so I didn’t re-check anything. Only, they switched left and right audio channels, so it could be a side effect when they updated some audio config file.
For the dragonfly, is it working with linux ? If yes, could you check the name of the Alsa driver it’s using ?
It’s working like a regular audio card on GNU/Linux, and AudioQuest announced a new version of the product for this year, as it’s known not to work with Android OTG, asking too much power.
OK, that is interesting thanks. Do you have a powered hub to check for power issue ? (i don’t)
Power is still the main problem, because when you plug a device in the USB port, it will at the same time :
  • draw from the battery
  • prevent you from plugging a power source
Anyone have problems with USB sticks? I have one with a micro USB connection that works when I plug it directly into my FP1, but the FP2 doesn’t see it at all. Not sure if it’s a general FP2 problem or because I’m using a self compiled FPOS.
As far as I have read, this might be a new bug introduced by the 1.2.8 update.
Details here:
https://forum.fairphone.com/t/fairphone-2-os-version-1-2-8-usb-otg-mounting/16397?u=johannes&source_topic_id=14267
thanks @m_dammer ! This post is a wiki, so could you please click on the topmost pencil icon and include your info there ?
off course :slight_smile: Info moved into the WiKi and original post deleted.
Plantronics Blackwire C510-M (USB headset):
http://b.pltcdn.com/images/catalog/product/large/blackwire-510.png
Google play and some other apps will use it for sound output, but phone app doesn’t use it at all, which is disappointing!
The two “Sound Recorder” apps (oops! 1 version would have been enough!), don’t use the mic on it either.
None of the 4 buttons work properly. Each one just toggles between phone speaker on and phone speaker off :frowning:
Shame, it’s partially there!
Edit: jaymanu - in Skype the headphones work, but the mic still doesn’t (it just uses the internal phone mic as in the other tests). I don’t use whatsapp, so I can’t test that one.
thanks !
Did you also try with whatsapp or skype calls ?
