Dear all,
I have a problem with my FP2 since two weeks ago that makes it useless (so I am using another mobile phone to ‘survive’). I write now because I was traveling last week.
The problem is that the screen has got crazy: it turns suddenly to grey (with mini-dots, like a TV without good reception), then randomly it appears to be normal (although it has a strange line in the top), then it turns immediately to the grey again, then the screen starts to become green, and finally it is grey until I remove the battery. This things happen in a random order. During this process, I can’t do anything with my phone, it doesn’t respond. When I restart the phone, it appears to be normal, but it starts again with these strange things. I tried to remove the SIM card, but it still works in the same bad way.
Has anyone the same problem? Is there anything that I can do by myself?
I attach some pictures to show you the problem… (the quality of the pictures is not so good but I hope they will help).
Than you very much!
IMAGES:
- Grey Screen
- Screen with a line at the top
- Screen becoming green
- Grey Screen after 30 minuts of leaving the FP alone
Image 1:
Image 2:
Image 3:
Image 4:
