Since the update to FPOpenOS 16.08 I experience random reboots and freezes of the UI. I updated OTA using the Fairphone Updater and recalibrated the proximity sensor right away. My phone is encrypted, but I don’t have Xposed nor microG installed.
At random times, sometimes on it own, sometimes during usage, most of the time right after unlocking the phone, the UI freezes. I then either end up at the lock screen again, or the phone does a soft reboot, without asking for the encryption password. Sometimes also the screen stays frozen and I have to force reboot the phone. During the reboots it also sometimes starts optimizing my apps again.
In order to fix it I already did a complete wipe by reinstalling OpenOD 16.08 using fastboot. And also by downgrading via fastboot to 16.07.1 again. However the problem returns after a short time.
Below is the output of adb logcat after a crash on 16.08:
--------- beginning of crash
F/libc ( 230): Fatal signal 4 (SIGILL), code 1, fault addr 0xb6ea2c98 in tid 230 (surfaceflinger)
I/DEBUG ( 2037): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 2037): Build fingerprint: 'Fairphone/FP2/FP2:5.1/FP2/fp2-sibon-16.08.0:userdebug/release-keys'
I/DEBUG ( 2037): Revision: '0'
I/DEBUG ( 2037): ABI: 'arm'
I/DEBUG ( 2037): pid: 230, tid: 230, name: surfaceflinger >>> /system/bin/surfaceflinger <<<
I/DEBUG ( 2037): signal 4 (SIGILL), code 1 (ILL_ILLOPC), fault addr 0xb6ea2c98
I/DEBUG ( 2037): r0 00000001 r1 7edf90fc r2 ffffffc8 r3 b6e86988
I/DEBUG ( 2037): r4 b6482000 r5 00000000 r6 be911af4 r7 00000001
I/DEBUG ( 2037): r8 00000014 r9 b6474550 sl ffffffcc fp b6482000
I/DEBUG ( 2037): ip b6ebdc48 sp be911680 lr b6ee5d14 pc b6ea2c98 cpsr 20070830
I/DEBUG ( 2037):
I/DEBUG ( 2037): backtrace:
I/DEBUG ( 2037): #00 pc 0001ac98 /system/lib/libsurfaceflinger.so
I/DEBUG ( 2037): #01 pc 0001a56d /system/lib/libsurfaceflinger.so
I/DEBUG ( 2037): #02 pc 000195c1 /system/lib/libsurfaceflinger.so
I/DEBUG ( 2037): #03 pc 00019329 /system/lib/libsurfaceflinger.so
I/DEBUG ( 2037): #04 pc 00011059 /system/lib/libutils.so (_ZN7android6Looper9pollInnerEi+408)
I/DEBUG ( 2037): #05 pc 0001114d /system/lib/libutils.so (_ZN7android6Looper8pollOnceEiPiS1_PPv+92)
I/DEBUG ( 2037): #06 pc 00016a25 /system/lib/libsurfaceflinger.so
I/DEBUG ( 2037): #07 pc 00018efd /system/lib/libsurfaceflinger.so (_ZN7android14SurfaceFlinger3runEv+8)
I/DEBUG ( 2037): #08 pc 00000b4d /system/bin/surfaceflinger
I/DEBUG ( 2037): #09 pc 0000fec9 /system/lib/libc.so (__libc_init+44)
I/DEBUG ( 2037): #10 pc 00000c08 /system/bin/surfaceflinger
F/libc (15875): Fatal signal 4 (SIGILL), code 1, fault addr 0xac27a71e in tid 15904 (RenderThread)
F/libc (13427): Fatal signal 4 (SIGILL), code 1, fault addr 0xac27a71e in tid 14159 (RenderThread)
F/libc (12956): Fatal signal 11 (SIGSEGV), code 1, fault addr 0x80 in tid 12956 (surfaceflinger)
F/libc (18967): Fatal signal 11 (SIGSEGV), code 1, fault addr 0x80 in tid 19080 (RenderThread)
F/libc (19229): Fatal signal 11 (SIGSEGV), code 1, fault addr 0x80 in tid 19229 (crime.securesms)
F/libc (19229): Fatal signal 11 (SIGSEGV), code 1, fault addr 0x80 in tid 19485 (AsyncTask #4)
F/libc (13188): Fatal signal 11 (SIGSEGV), code 1, fault addr 0x80 in tid 13295 (android.display)
I/DEBUG (17635): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG (17635): Build fingerprint: 'Fairphone/FP2/FP2:5.1/FP2/fp2-sibon-16.08.0:userdebug/release-keys'
I/DEBUG (17635): Revision: '0'
I/DEBUG (17635): ABI: 'arm'
I/DEBUG (17635): pid: 12956, tid: 12956, name: surfaceflinger >>> /system/bin/surfaceflinger <<<
I/DEBUG (17635): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x80
I/DEBUG (17635): r0 ffffff2c r1 00000000 r2 0000000c r3 00000000
I/DEBUG (17635): r4 0000000c r5 b6f19fd8 r6 00000000 r7 00000008
I/DEBUG (17635): r8 b5c3a118 r9 b6f19fd8 sl 0003a118 fp 0000000c
I/DEBUG (17635): ip 00000001 sp be866da8 lr b6ef3395 pc b6ef2fae cpsr 80070030
I/DEBUG (17635):
I/DEBUG (17635): backtrace:
I/DEBUG (17635): #00 pc 0003efae /system/lib/libc.so (je_arena_ralloc_no_move+37)
I/DEBUG (17635): #01 pc 0003f391 /system/lib/libc.so (je_arena_ralloc+48)
I/DEBUG (17635): #02 pc 00048823 /system/lib/libc.so (je_realloc+426)
I/DEBUG (17635): #03 pc 0000fe13 /system/lib/libc.so (realloc+10)
I/DEBUG (17635): #04 pc 0001fe6b /system/lib/libbinder.so (_ZN7android6Parcel13continueWriteEj+362)
I/DEBUG (17635): #05 pc 00020699 /system/lib/libbinder.so (_ZN7android6Parcel12writeAlignedIiEEiT_+36)
I/DEBUG (17635): #06 pc 000206f5 /system/lib/libbinder.so (_ZN7android6Parcel13writeString16EPKtj+26)
I/DEBUG (17635): #07 pc 00030fa1 /system/lib/libgui.so
I/DEBUG (17635): #08 pc 000293f5 /system/lib/libgui.so (_ZN7android19BufferQueueConsumer13releaseBufferEiyRKNS_2spINS_5FenceEEEPvS6_+412)
I/DEBUG (17635): #09 pc 00028233 /system/lib/libgui.so
I/DEBUG (17635): #10 pc 0002c719 /system/lib/libgui.so (_ZN7android12ConsumerBase19releaseBufferLockedEiNS_2spINS_13GraphicBufferEEEPvS4_+84)
I/DEBUG (17635): #11 pc 0002df33 /system/lib/libgui.so (_ZN7android10GLConsumer19releaseBufferLockedEiNS_2spINS_13GraphicBufferEEEPvS4_+32)
I/DEBUG (17635): #12 pc 0002eec5 /system/lib/libgui.so (_ZN7android10GLConsumer22updateAndReleaseLockedERKNS_22IGraphicBufferConsumer10BufferItemE+348)
I/DEBUG (17635): #13 pc 000217cd /system/lib/libsurfaceflinger.so
I/DEBUG (17635): #14 pc 000154bf /system/lib/libsurfaceflinger.so
I/DEBUG (17635): #15 pc 0001998d /system/lib/libsurfaceflinger.so
I/DEBUG (17635): #16 pc 0001948f /system/lib/libsurfaceflinger.so
I/DEBUG (17635): #17 pc 00019339 /system/lib/libsurfaceflinger.so
I/DEBUG (17635): #18 pc 00011059 /system/lib/libutils.so (_ZN7android6Looper9pollInnerEi+408)
I/DEBUG (17635): #19 pc 0001114d /system/lib/libutils.so (_ZN7android6Looper8pollOnceEiPiS1_PPv+92)
I/DEBUG (17635): #20 pc 00016a25 /system/lib/libsurfaceflinger.so
I/DEBUG (17635): #21 pc 00018efd /system/lib/libsurfaceflinger.so (_ZN7android14SurfaceFlinger3runEv+8)
I/DEBUG (17635): #22 pc 00000b4d /system/bin/surfaceflinger
I/DEBUG (17635): #23 pc 0000fec9 /system/lib/libc.so (__libc_init+44)
I/DEBUG (17635): #24 pc 00000c08 /system/bin/surfaceflinger
I/DEBUG (17635): pid: 18967, tid: 19080, name: RenderThread >>> com.android.systemui <<<
I/DEBUG (17635): ptrace attach to 18967 failed: Operation not permitted
I/DEBUG (17635): ptrace attach to 19072 failed: No such process
I/DEBUG (17635): ptrace attach to 19075 failed: No such process
I/DEBUG (17635): ptrace attach to 19076 failed: No such process
I/DEBUG (17635): ptrace attach to 19077 failed: No such process
I/DEBUG (17635): ptrace attach to 19078 failed: No such process
F/libc (19821): Fatal signal 11 (SIGSEGV), code 1, fault addr 0x80 in tid 19923 (android.ui)
F/libc (20048): Fatal signal 11 (SIGSEGV), code 1, fault addr 0x80 in tid 20744 (RenderThread)
I/DEBUG (19662): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG (19662): Build fingerprint: 'Fairphone/FP2/FP2:5.1/FP2/fp2-sibon-16.08.0:userdebug/release-keys'
I/DEBUG (19662): Revision: '0'
I/DEBUG (19662): ABI: 'arm'
I/DEBUG (19662): pid: 19821, tid: 19923, name: android.ui >>> system_server <<<
I/DEBUG (19662): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x80
I/DEBUG (19662): r0 ffffff2c r1 00000000 r2 0000000c r3 00000000
I/DEBUG (19662): r4 0000000c r5 b6ebefd8 r6 00000000 r7 00000008
I/DEBUG (19662): r8 b00300f8 r9 b6ebefd8 sl 000300f8 fp 0000000c
I/DEBUG (19662): ip 00000001 sp a25cca88 lr b6e98395 pc b6e97fae cpsr 800f0030
I/DEBUG (19662):
I/DEBUG (19662): backtrace:
I/DEBUG (19662): #00 pc 0003efae /system/lib/libc.so (je_arena_ralloc_no_move+37)
I/DEBUG (19662): #01 pc 0003f391 /system/lib/libc.so (je_arena_ralloc+48)
I/DEBUG (19662): #02 pc 00048823 /system/lib/libc.so (je_realloc+426)
I/DEBUG (19662): #03 pc 0000fe13 /system/lib/libc.so (realloc+10)
I/DEBUG (19662): #04 pc 0001fe6b /system/lib/libbinder.so (_ZN7android6Parcel13continueWriteEj+362)
I/DEBUG (19662): #05 pc 00020699 /system/lib/libbinder.so (_ZN7android6Parcel12writeAlignedIiEEiT_+36)
I/DEBUG (19662): #06 pc 000206f5 /system/lib/libbinder.so (_ZN7android6Parcel13writeString16EPKtj+26)
I/DEBUG (19662): #07 pc 00032471 /system/lib/libgui.so
I/DEBUG (19662): #08 pc 0003841f /system/lib/libgui.so (_ZN7android8Composer26closeGlobalTransactionImplEb+194)
I/DEBUG (19662): #09 pc 00006c75 /data/dalvik-cache/arm/system@framework@boot.oat
I/DEBUG (19662): pid: 20048, tid: 20744, name: RenderThread >>> com.android.systemui <<<
I/DEBUG (19662): r8 a367f8b0 r9 b6ebefd8 sl 0027f8b0 fp 0000000c
I/DEBUG (19662): ip 00000001 sp a22c39c0 lr b6e98395 pc b6e97fae cpsr 80010030
I/DEBUG (19662):
I/DEBUG (19662): #07 pc 0002ff07 /system/lib/libgui.so
I/DEBUG (19662): #08 pc 000367ed /system/lib/libgui.so (_ZNK7android7Surface5queryEiPi+180)
I/DEBUG (19662): #09 pc 000363a3 /system/lib/libgui.so (_ZN7android7Surface10hook_queryEPK13ANativeWindowiPi+10)
I/DEBUG (19662): #10 pc 0003abe7 /system/lib/libhwui.so
I/DEBUG (19662): #11 pc 0003b49d /system/lib/libhwui.so
I/DEBUG (19662): #12 pc 0003b539 /system/lib/libhwui.so
I/DEBUG (19662): #13 pc 0003d157 /system/lib/libhwui.so (_ZN7android10uirenderer12renderthread12RenderThread10threadLoopEv+66)
I/DEBUG (19662): #14 pc 0000ef55 /system/lib/libutils.so (_ZN7android6Thread11_threadLoopEPv+112)
I/DEBUG (19662): #15 pc 0005b949 /system/lib/libandroid_runtime.so (_ZN7android14AndroidRuntime15javaThreadShellEPv+72)
I/DEBUG (19662): #16 pc 0000eac5 /system/lib/libutils.so
I/DEBUG (19662): #17 pc 00013fc3 /system/lib/libc.so (_ZL15__pthread_startPv+30)
I/DEBUG (19662): #18 pc 00011f0b /system/lib/libc.so (__start_thread+6)
And the output after a crash on OpenOS 16.07.1:
F/libc ( 3987): Fatal signal 11 (SIGSEGV), code 1, fault addr 0xdff71750 in tid 3987 (ndroid.settings)
I/DEBUG ( 1969): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG ( 1969): Build fingerprint: 'Fairphone/FP2/FP2:5.1/FP2/fp2-sibon-16.07.1:userdebug/release-keys'
I/DEBUG ( 1969): Revision: '0'
I/DEBUG ( 1969): ABI: 'arm'
I/DEBUG ( 1969): pid: 3987, tid: 3987, name: ndroid.settings >>> com.android.settings <<<
I/DEBUG ( 1969): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0xdff71750
I/DEBUG ( 1969): r0 6ffb8ba8 r1 22d18f00 r2 22d6a6a0 r3 00000000
I/DEBUG ( 1969): r4 00000002 r5 22d20400 r6 22d6a6a0 r7 6ffb8ba8
I/DEBUG ( 1969): r8 6ff75138 r9 b4827800 sl 00000041 fp 22d18f00
I/DEBUG ( 1969): ip a3879880 sp bef6d8f0 lr 00000000 pc 731a2c9a cpsr 00010030
I/DEBUG ( 1969):
I/DEBUG ( 1969): backtrace:
I/DEBUG ( 1969): #00 pc 00ea7c9a /data/dalvik-cache/arm/system@framework@boot.oat
I/DEBUG ( 1969): #01 pc 00000000 <unknown>
F/libc ( 1970): Fatal signal 4 (SIGILL), code 1, fault addr 0xb5ff86a0 in tid 2138 (rild)
F/libc ( 1970): Fatal signal 11 (SIGSEGV), code 2, fault addr 0xb545e1b7 in tid 2138 (rild)
F/libc (15894): Fatal signal 4 (SIGILL), code 1, fault addr 0xac20e71e in tid 15933 (RenderThread)
F/libc ( 230): Fatal signal 4 (SIGILL), code 1, fault addr 0xb6ed25f0 in tid 303 (DispSync)
F/libc ( 230): Fatal signal 4 (SIGILL), code 1, fault addr 0xb6ed25f0 in tid 3381 (Binder_5)
I/DEBUG (20821): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG (20821): Build fingerprint: 'Fairphone/FP2/FP2:5.1/FP2/fp2-sibon-16.07.1:userdebug/release-keys'
I/DEBUG (20821): Revision: '0'
I/DEBUG (20821): ABI: 'arm'
I/DEBUG (20821): pid: 230, tid: 3381, name: Binder_5 >>> /system/bin/surfaceflinger <<<
I/DEBUG (20821): signal 4 (SIGILL), code 1 (ILL_ILLOPC), fault addr 0xb6ed25f0
I/DEBUG (20821): r0 b6696298 r1 aee9d624 r2 b66e39f0 r3 00000000
I/DEBUG (20821): r4 aee9d624 r5 b6695000 r6 aee9d624 r7 b6688cc0
I/DEBUG (20821): r8 b6482000 r9 b6482000 sl b6471560 fp 00000000
I/DEBUG (20821): ip 00000001 sp aee9d5e0 lr b6ed3fe1 pc b6ed25f0 cpsr 600e0030
I/DEBUG (20821):
I/DEBUG (20821): backtrace:
I/DEBUG (20821): #00 pc 0000c5f0 /system/lib/libsurfaceflinger.so
I/DEBUG (20821): #01 pc 0000dfdd /system/lib/libsurfaceflinger.so
I/DEBUG (20821): #02 pc 0000df71 /system/lib/libsurfaceflinger.so
I/DEBUG (20821): #03 pc 0001cacf /system/lib/libsurfaceflinger.so
I/DEBUG (20821): #04 pc 0001c795 /system/lib/libsurfaceflinger.so
I/DEBUG (20821): #05 pc 000333e9 /system/lib/libgui.so (_ZN7android17BnSurfaceComposer10onTransactEjRKNS_6ParcelEPS1_j+420)
I/DEBUG (20821): #06 pc 0001e05d /system/lib/libsurfaceflinger.so
I/DEBUG (20821): #07 pc 00017fad /system/lib/libbinder.so (_ZN7android7BBinder8transactEjRKNS_6ParcelEPS1_j+60)
I/DEBUG (20821): #08 pc 0001cf89 /system/lib/libbinder.so (_ZN7android14IPCThreadState14executeCommandEi+564)
I/DEBUG (20821): #09 pc 0001d0bb /system/lib/libbinder.so (_ZN7android14IPCThreadState20getAndExecuteCommandEv+38)
I/DEBUG (20821): #10 pc 0001d0fd /system/lib/libbinder.so (_ZN7android14IPCThreadState14joinThreadPoolEb+48)
I/DEBUG (20821): #11 pc 0002127f /system/lib/libbinder.so
I/DEBUG (20821): #12 pc 0000ef55 /system/lib/libutils.so (_ZN7android6Thread11_threadLoopEPv+112)
I/DEBUG (20821): #13 pc 0000eac5 /system/lib/libutils.so
I/DEBUG (20821): #14 pc 00013fc3 /system/lib/libc.so (_ZL15__pthread_startPv+30)
I/DEBUG (20821): #15 pc 00011f0b /system/lib/libc.so (__start_thread+6)
F/libc ( 1973): Fatal signal 13 (SIGPIPE), code 0 in tid 1973 (installd)
Has anybody else experienced something like this? What can I do to fix this?
