After last update(8-1-22) a lot of Apps have been removed. Reinstall is not possible because of less space, but only 20GB of 32GB is used.
At first I would like to go back to OS before last update
You can go back using manual installation:
But still your problem sounds strange. Maybe we could help with further diagnosing that?
Are you sure the apps are really removed – or have the apps only disappeared from the home screen? Did you check Settings > Apps & notifications > See all … apps … etc. if the missing apps are listed there?
