Hello.
I have been using FP2 OpenOS for quite a moment and upgraded recently in Android9 (21.03.0-rel2). I am using stores F-Droid, but also APKPure (or Aurora Store in anonymous mode) for some private apps as Signal for example.
To read documents, I use Librera PRO for pdf files but could you tell me about an apps that allows to read documents such as word, excel, ppt, LibreOffice (odt, ods, odp) ?
There are lots of them but they are all tagged with adds and need GSF (what does it means?).
I found this one âAll Documents Viewer/ Visionneuse de tous les documentsâ that is not indicating having adds though it makes you sign their genral conditions of use indicating they have them and besides takes your datas for G analyticsâŠ!!!
The only apps I found is âLibreOffice Viewerâ from F-Droid, but it is a bit slow : do you know any alternative ?
Thank you very much for your informations, if you have some:).
Collabora Office! Itâs the best app for such editing I have ever found, based on LibreOffice.
Youâll have to add it as an F-Droid repo. Go in F-Droid settings, repositories, +, paste the following link : Index of /downloads/fdroid/repo
Then update the repositories in F-Droid (just pull down from the main page) and you should find two new apps: Collabora Office 6.4 and Collabora Office Snapshot. The snapshot version is a nightly (updated every day from the source) and the normal one once a week.
Itâs not very fast (wouldnât expect so on a FP2), but works really well.
Hello Alexis : thank you very much for your help and your indications !
It did what you indicated but on my FP2, it says the apps is not compatible âapplication non compatible avec votre appareil, lâinstaller quand mĂȘme ?â. I tried to install it all the same but it doesnât work, so I guess I will continue to use âLibre Office Viewerâ that makes the job for the momentâŠ
Oh, yes, Iâve been having this problem as well.
In F-Droid on the appâs page, just go down, open the âVersionsâ tab, and then install the second one, the one compatible with armeabi-v7a, itâs the one compatible with the FP2. For some reason it isnât selected automatically.
Then it should work.
Okay, with images. Can you install this version? (instead of "Aktualisieren you should have âInstallâ
Bon, avec des images. Est-ce que tu peux installer cette version? (au lieu de âAktualisierenâ tu devrais avoir âInstallerâ)
Incredible: thanks a lot, it works! Who said âinformatics are exact science â?
Incroyable: merci vraiment beaucoup, ça marche! Qui a dit que âliânformatique est une science exacte â?
