Hi!
One week ago my phone started making some strange noise. I was on a call and after ending the call I put the phone on my desk and at once a strange cracking noise came out of the phone, it sounden so wierd that it’s hard to discribe but it freaked me out! And I thought that was the deathhowl of my phone after all shit we been trough. But the phone worked just perfectly well, until a couple days ago when suddenly no one can hear me while talkibg in the phone and that is a problem I’m well aware of that quite a lot of you have. Anyone more that me with a creepy phone?
did you check if the bottom module is a bit loose? This would explain the crackling noise if the connection to the other parts is not tight enough.
You only need a small screwdriver to check this.
