My FP2 took a swallow dive into the ocean a week or so ago. I immediately fished it up again, and disassembled the battery, and put the FP2, back cover and battery in my backpack. At home, an hour or so later, I disassembled all the modules from the core module, and rinsed them thoroughly in fresh water, and put them in my hot air stove on 50 degC for several hours.
After reassembling the FP2 again, it is no longer able to boot up completely into Fairphone OS. Sometimes it reaches the point where I can press the PIN code, other times it just reboots right after the bootloader finishes (the FAIRPHONE logo on black screen, a couple of seconds when powering up).
I tried reflashing the phone using step 4 in this article (https://support.fairphone.com/hc/en-us/articles/207914363-Manually-install-Fairphone-OS-for-the-Fairphone-2), thinking that the immersion in water had corrupted the data in some way. Flashing the FP2 worked fine. But the reboot behavior is the same.
Anybody’s got an idea to what it is that’s causing this behavior?
Thanks for any help!
