FP2 file transfer can't be done by charger cable
I can no longer transfer my files using the charger cable. Before I got a message asking me if I wanted to charge the phone or transfer files, but I don’t get that message any more and the charger automatically charges. How to transfer files like I used to? Thanks for any help!
Did you use a different cable before? A USB data cable must be used.
Are you aware that your phone has to be unlocked to show the message? Did you cross-check that?
If nothing else helps you might consider to enable #dic:developeroptions and there “USB debugging”.
I did change the cable, but seem to remember this one working at some point. I’ll try this option and see if it works. Thanks!
