The bottom module of my FP2 has broken and needs replacing. Anyone in the UK have a replacement would be very appreciated.
NB: If you are interested and want to send a direct message, please check #how-to-dm .
Be aware, that cross-border shipment of batteries outside a phone is virtually impossible for individuals .
Hi @annalowenstein Welcome to the forum.
If you want to keep using your FP2 and don’t find a replacement bottom module you could try and get it fixed.
You don’t say what is wrong with it but may like to see topics/posts on options to repair.
@JohnHughes (thanks again) send me two broken bottom Modules some days ago. This one has a defekt µUSB port.
After disassembling I took a picture with a microscope camera and found some solder cracks. Barely to see without magnification. Two cracks at the shield contacts that I am not too worry about, but also one at contact 5. I am sure that was a slack joint. Some serious force must be acted to the Port.
I will try to resolder the joints and hope the bottom module will be able to do its work…
As fairphone angel (in Berlin) I have a lot of support cases with nonfunctional microphones in the bottom modul. A lot of users have minimum the 2nd, often the 3rd bottom module. Mostly easily changed by Fairphone support in warranty.
But there is a lot of waste (I collect old faulty modules and send them back for recycling).
So my questions:
Did anyone successfully repaired the microphone inside the bottom module by soldering a new smd microphone?
What’s the reason for the highly rate of f…
thanks Amou,
unfortnately mine is out of warranty so cant get it fixed.
The fixes were done either DIY or via a shop
Hi! I also live in the UK. Are you interested in buying a used (6 months) FP3?
I got mine just last March? because my old phone stopped working then after a few months it started working again. I’m currently on holiday but once I go back home in a week’s time I can send you photos of the box, case and phone?
system
Closed
October 24, 2021, 2:20pm
6
