Hi
I’ve upgraded to Android 6 but the LED no longer provides notification.
Any ideas?
Thanks
Will
Hi
Any ideas?
Thanks
Will
Is your LED not working witn all apps? Or do some apps still work with LED notification?
Is your LED working when you charge your phone?
Thank you for your reply. LED not working with any apps. It does work when charging and to indicate that the phone is fully charged.
LED Blinker Lite test does not work.
I’ve just sent myself an SMS from another phone…and the LED is now working. I’ll try removing the LED Blinker app and reinstalling it.
I’m still curious as to why there is no setting in the settings, however.
That did the trick…sorry to have wasted anybody’s time reading this thread…
