Hi, I have several problems with fp1. The two sim cards are sometimes in searching mode, then the wlan can’t be activated. When I restart, then the sim-cards are doing and also the wlan works.
But then after a while I have the same problem again.
Now, one week later I saw, that the phone is sometimes rebooting.
And today, I’m not able to turn on the phone.
I tried with another akku, but I have no luck. I also took of the sim-cards and the storage card, but I’m not able to boot it again (therefore I can also not make a hard reset).
What spare part may be the problem and how can I fix this?
Your best chance to find out which part is broken, is to go to #dic:testingmode and do a full test (beware, don’t do this in a public place, the sound test is like a firefighter siren! )
It would be great if you could post a photo of the result.
The battery isn’t the problem, even the test says that. Because I have a second one (respectively a second Fairphone 1). When I change the battery I have the same problems. And on the other phone, we have no battery problems.
At the moment, I’m not able to start the phone at all. Last sign of life was a blue screen… So I can’t run the test mode, right now…
Could it be the motherboard, which ist going to die? Or do I have to change the phone itself?
