GravityBox allows you to change which buttons are in the pull-down menu and in which order.
I tried to connect my phone to a BLE heart-rate monitor yesterday.
I could see the device in the bluetooth settings and pairing didnāt work from there (that is the correct behaviour).
But the three apps I tried didnāt manage to find the device.
Iām trying to get more information on this isssue over the next days.
Has anybody tried this yet? Did it work?
Edit: Both BLExplorer and iBeaconDetector (both on F-Droid and on Google Play) detect a device, but Iām not sure if itās the right one. BLExplorer does connect to a device but doesnāt return any information about it.
Edit 2:
iBeaconDetector was able to find the device.
BLExplorer was able to find the device and list its capabilities (but not read the concrete values).
I took a closer look at one of the apps I tried - RunnerUp. And I noticed these lines:
static boolean AVOID_SCAN_WITH_UUID = false;
static boolean CONNECT_IN_OWN_THREAD_FROM_ON_LE_SCAN = false;
static {
if (Build.VERSION.SDK_INT <= Build.VERSION_CODES.JELLY_BEAN_MR2) {
// 4.3
AVOID_SCAN_WITH_UUID = true;
CONNECT_IN_OWN_THREAD_FROM_ON_LE_SCAN = true;
So, Android 4.3 seems to be lacking certain features.
I replaced this with the following:
static boolean AVOID_SCAN_WITH_UUID = true;
And scanning for devices does work now.
Connecting does not.
So, what Iāve learned so far:
- BLE devices have an ID and capabilities.
- Apps can search for BLE devices.
- They can add filters to scan only for BLE devices for certain capabilities.
- The BLE stack in this ROM doesnāt support those filters.
The real solution would be to make filtering work.
The quick and dirty solution would be to simply ignore any filters set by apps in android.bluetooth.BluetoothAdapter
public boolean startLeScan(UUID[] serviceUuids, LeScanCallback callback) {
serviceUuids = null;
[ā¦]
This could be made into an XPosed module easily, I guess. Maybe.
Iāll try setting the next variable to true
Edit 3: Hereās the XPosed module:
The code is really just this:
findAndHookMethod("android.bluetooth.BluetoothAdapter", null, "startLeScan", UUID[].class, LeScanCallback.class, new XC_MethodHook() {
@Override
protected void beforeHookedMethod(XC_MethodHook.MethodHookParam param) throws Throwable
param.args[0] = null;
Edit 4: Iāve tried setting the second variable to true
. It didnāt help the connection.
So, the things Iāve learned so far:
- The FP1 does have BLE support. It just doesnāt work the way it should.
- Scanning for devices works mostly (eg. BLExplorer or iBeaconDetector or RunnerUp after the mentioned modification).
- Filtering does not. Many apps know that and donāt bother setting a filter (eg. adidas train & run or Runtastic).
- Discovering the services / properties a BLE device has works (eg. BLExplorer or RunnerUp).
- Connecting to a BLE device does not.
- Scanning for a BLE device does not work from some apps (eg. adidas train & run or Runtastic - the former one calls
startLeScan
very often).
Edit 5: What does happen when using RunnerUp is this:
- Enable Bluetooth.
- Scan.
- Found a device.
- Stop scan.
- Connect to the device.
- Connected.
- Start service discovery.
- Disconnected. (Should be āDiscovered services.ā.)
BLExplorer is able to list the services.
Edit 6: I bought a relatively cheap beacon.
BLExplorer is able to find the device and list its services. It is also able to read the values of one service per connection. (So I have to close the app and reopen it to read all services.)
The app made specifically for this device (Gigaset G-tag app) was able to find and connect to the device at the third attempt but lost the connection after about one minute.
Sometimes, the app Bluetooth-Freigabe (I donāt know its English name nor its package name, yet, sorry) crashes (I donāt have a stacktrace yet). No devices are being found afterwards until the next reboot.
Edit 7: This G-tag seems to work mostly. Sometimes, there are disconnects, but it reconnects very quickly. This is good, but doesnāt help with my heart rate monitor.
And I got a stack trace from the crashes of com.android.bluetooth
somewhere in my logs. I just need to find itā¦
Edit 8: Hereās a stack trace:
E/[Bluetooth.OPP]BtOppRfcommListener(13444): Error accept connection java.io.IOException: read failed, socket might closed or timeout, read ret: -1
E/MTKBT (13444): [Session]the session[61458][13444] is not ready to monitor
E/MTKBT (13444): [Session]no any more session is in list
E/Bluetooth Transport(22023): Socket Type: Secureaccept() failed
E/Bluetooth Transport(22023): java.io.IOException: read failed, socket might closed or timeout, read ret: -1
E/Bluetooth Transport(22023): at android.bluetooth.BluetoothSocket.readAll(BluetoothSocket.java:508)
E/Bluetooth Transport(22023): at android.bluetooth.BluetoothSocket.waitSocketSignal(BluetoothSocket.java:485)
E/Bluetooth Transport(22023): at android.bluetooth.BluetoothSocket.accept(BluetoothSocket.java:398)
E/Bluetooth Transport(22023): at android.bluetooth.BluetoothServerSocket.accept(BluetoothServerSocket.java:131)
E/Bluetooth Transport(22023): at android.bluetooth.BluetoothServerSocket.accept(BluetoothServerSocket.java:117)
E/Bluetooth Transport(22023): at ewa.run(SourceFile:432)
E/CellLocation(14358): create GsmCellLocation
E/BluetoothRemoteDevices(13444): aclStateChangeCallback: Device is NULL
E/BluetoothTethering(12657): attempted to stop reverse tether with nothing tethered
E/bt_ext_apis.c(13444): create bt.ext.adp.hfp external socket failed : Address already in use, errno=98!
And here is the crash:
E/AndroidRuntime(13444): FATAL EXCEPTION: BluetoothAdapterState:
E/AndroidRuntime(13444): Process: com.android.bluetooth, PID: 13444
E/AndroidRuntime(13444): java.lang.NullPointerException
E/AndroidRuntime(13444): at com.android.bluetooth.btservice.RemoteDevices$DeviceProperties.access$400(RemoteDevices.java:100)
E/AndroidRuntime(13444): at com.android.bluetooth.btservice.RemoteDevices.sendUuidIntent(RemoteDevices.java:219)
E/AndroidRuntime(13444): at com.android.bluetooth.btservice.RemoteDevices.access$1000(RemoteDevices.java:37)
E/AndroidRuntime(13444): at com.android.bluetooth.btservice.RemoteDevices$1.handleMessage(RemoteDevices.java:455)
E/AndroidRuntime(13444): at android.os.Handler.dispatchMessage(Handler.java:110)
E/AndroidRuntime(13444): at android.os.Looper.loop(Looper.java:193)
E/AndroidRuntime(13444): at android.os.HandlerThread.run(HandlerThread.java:61)
Edit 9: The system does return devices when an app scans for them (unless thereās a filter set). But many apps donāt display any found devices.
Edit 10: I tried going back to pre2. Itās basically the same.
Edit 11: I tried going back to the unofficial 4.4.4 build. Itās the same.
Scanning takes very long and eventually finds the correct device. But it takes a few attempts. Even if the two devices are directly near the phone.
I guess many apps run into a timeout before.
Improving the scanning process would be nice. (But not that important. We didnāt have BLE in 4.2 - now we have it but it doesnāt work.)
The BLE functionality is a bit unreliable - see the dedicated thread āBluetooth connections are unstable in FP1 alphaā thread
The system isnāt able to display the įŗ
(the uppercase version of Ć
; U+1E9E
; ālatin capital letter sharp sā).
The fonts installed support it partially:
- DroidSansFallback: nope
- DroidSansMono: nope
- DroidSerif-Regular: yep
- Roboto: nope
It would be great if the fonts could be updated. (But not that important.)
same experience here, snapchat records vids, replay them properly, but when sended out, the recevier can only see distortion (grey blocks and green marks).
same for whatsapp with shortened vids.
i am on macademian 1.9.9 pre3 alphaā¦
Hey Fairphone Team,
I know that you are doing your best and so I would like to ask when the next beta will be published.
My problem is that with the pre3 my battery only last 12-24 hours and its a new oneā¦
Thanks!
I would be interested in some news as well
This was in @chrmhoffmannās build too, so it seems to be a regression in [hardware?] video encoder from 4.2 to 4.4.
That sounds like normal battery life for a phone in regular use
About batteryā¦ it is only a feeling (i have no time measurement and compare) but i think in pre3, the battry lasts not as long as in 4.2ā¦ shure, it depends on how you use your phone, but normally, i was able to use my phone at least 2 days (switched off in the night), means at least 24h, maybe 30h. now i have to recharge after 1.5 days, it feels like i have around 3-6 hours less.
When i check my battery stats, it showes that the WLAN is always on. during the day, i switch it off, but the stats tell me that WLAN is on all the time. Maybe it is only a graphical mistake, but maybe wlan does not switch of properly?
R.
Yes, for normal use 12-24 h would be ok. But even if I use it only a bit it is empty after this time.
It is definitively worse than with 4.2 or @chrmhoffmannās build. (I have two relatively new batteries, and it is the same with both)
If I remember correctly, it was in the old official releases, too. So itās not even a regression. Itās just a bug.
I have the pre3 installed, without GApps, and it lasts for two to 3 days normaly, with Conversations and Linphone running, Wireless on almost all the time.
Wow @YtvwlD, serious detective work going on!
I work for a company developing a BLE device. Our app will only work an Android 5.0+ because the BLE stack is simply to unstable and lacking on older Android Platforms (startLeScan is marked deprecated for a reason ;-)). Still, filtering by serviceUUIDs should be possible on 4.4 and ignoring this filter can have a serious impact on battery life, because apps will use the startLeScan to determine if a known device type is nearby, which can cause connection attemps, for example.
Well, yeah. Scanning is really flakey. It takes too long and doesnāt find a device way too often.
I donāt know what part of the issues comes from the Mediatek Bluetooth stack and what part comes from the old version of Android.
An upgrade to Lollipop could improve things. @jftr, @Douwe there is no planning regarding a newer Android than KikKat for the FP1, is it?
Read a lengthy explanation why Lollipop is not possible, from someone who has tried:
Iāve already read this thread.
If I remember correctly, it isnāt impossible, just very unlikely and difficult.
Yes, you are right. Iāve given up on that hope thoughā¦
[emphasize by me]. .
Continue here:
