Is it possible to have a first package with just playstore? and then imagine that we can download everything else needed? just as pico or nano of openGapps?
Ok, Iâll send the output of adb bugreport
along. After dumping the data I told my phone to reboot into recovery using adb reboot recovery
. I saw a faint (because of the screen issue) boot animation and then the android droid with âKein Befehlâ under it. The whole time the screen was getting darker and darker.
[quote=âjftr, post:271, topic:19450â]
Before turning off your phone, make sure to have backed up any data that is important for you.
[/quote]Thatâs no problem, important data is mirrored across other devices.
If Iâm not mistaken this is solved with gravity boxâŚ
Thatâs certainly possible. I just wonder whatâs most useful for most users ⌠I believe most users expect to get at least some basic apps when installing GApps. I donât know what the sweet spot is. Iâll think about it.
Easier to install apps we want than to get rid of apps we donât!
There is a different xPosed module that provides the functionality, but I thought it would be better if the solution is native.
Youâre right⌠. (which module ?)
I posted the link above, but here it is again: Emoticons - Convert SMS to MMS at a price! (one post further down).
Havenât seen that⌠thanks
@jftr I have no idea, what the warning means, but you might want to look into this:
Developer warning: android.permission.ACCESS_SUPERUSER wasnât declared in the manifest.
The red writing could look a bit off-putting to peopleâŚ
This is normal behavior of Superuser. There might be a setting of Superuser (Settings > # Superuser > ⌠menu > Settings).
Edit: It essentially means that the app tries to get root privileges without declaring so in its manifest.
Last time I read about it, ACCESS_SUPERUSER was deprecated. See also here:
Oh, so the warning is referring to the appâs manifest. Ok never mind then!
@jftr just reporting back, had my device set aside (not booted up) for a while again and had no visible flickering until Iâve unlocked the simcard but then it started again and is getting worse but seams to take longer this time. I still hope itâs not the hardware as new Display looks hard to come by - and the fp2 is a bit to big for my taste.
While the preinstalled (gapps) version of âGoogle News & Weatherâ canât connect to the servers (maybe too old version), updating to a newer version and starting it results in an error message, saying that my device isnât compatible (but it was working on Android 4.2). Is there a way to fix this please?
Unfortunately I could not find any cause for this. It really looks like it is a hardware issue. One thing that you could do to verify: Go back to the stable version 1.8.7 and see if that changes anything.
Thanks for reporting this. Apparently there is some incompatibility with the GApps package. I see whether we can fix that.
I have a big notification problem (or synchronization Iâm not sure)âŚ
I only get my messages when I open the application⌠The worse is whatsapp. I have to go in the application to see if I have any messages. Anyone else having this problem?
Can you please give some details:
I figure, you have GApps installed.
Do you have any non-standard configurations (XPosed, etc.)?
In general this sounds like some battery optimization setting is too aggressive. Did you enable anything along this line?
Edit: One standard way that could help solve this issue:
- Android Phone Settings > Data Usage > Menu > uncheck âRestrict background dataâ or make sure you see âAllow background dataâ
The complete update is FAR from being released, itâs not just some bluetooth problems, I installed the software-update, also gapps, did all updates and now, when I boot the phone it starts with:
- google play boeken stopped, play films stopped (x4).
- my battery drains twice as fast as with android 4.2
- not mentioning the bluetooth issues
- volume control with alarms: difficult to describe but the volume changes randomly, I cannot even use the phone to wake up anymore.
and the worst of all: I try to go back using the instructions, but this results in : Error: System property does not match Installation aborted.
Please help
