It is with great disappointment that I discover that my FP1 became obsolete after only 2 ½ years. The
android version no longer supports the updates of the apps, so I am
obliged to change phone because no update is planned for FP1. Really disappointed…
My
phone crash minimun twice an hour, its use has become impossible, I had
to uninstall several apps, it is no longer a smartphone, just a basic
phone that often crashes.
We can’t say yet because they are still trying to fix some annoying bugs (battery stats, GPS, bluetooth). It is in active development though (I myself am using the alpha version at the moment and it works stable).
Consider using your phone in safe mode for a while to find out if the crashes are caused by some third-party apps:
Have to say my old FP1 is working fine although I dont use that many apps , still a firm FAIRPHONE man and will keep using my FP1 for as long as possible
The deadline is rather one week, one month, six months?
I can not switch to safe mode. I keep pressing the button for a long time but no menu appears to switch to safe mode. The phone reboots without providing safe mode
I also do not understand why the tests fail because the cameras work for example. I can use my phone normally in safe mode, but it crashes regularly anyway. There it just crashes after sending an SMS
This sounds like a severe hardware failure. It seems that the crashes occur when the phone is trying to send data over the network (in this case an SMS). With more apps installed, if course the phone uses the network more often (thus more crashes).
To rule out a software issue, you should make a thorough backup and do a hard reset.
If after the hard reset you still experience crashes, I’m afraid your modem is broken (or something else too), which basically renders your motherboard useless.
The crash is not systematic. After booting safe mode, the phone can crash just by sending an SMS or using firefox. But for example at the last restart of the safe mode, I was able to use, firefox, mail, “clash royal” and other apps without crash. Today, my phone had to crash a dozen times in safe mode.
Oddly my phone now works normally. Although it crashed even in safe mode, since Sunday afternoon it no longer crashes in safe mode. So I put it back in normal mode, I reinstalled the apps I had uninstalled and everything is fine at the moment. I do not understand what happened. Either
a problem of false contact or a problem of humidity or condensation
because the problems started when the weather became cold.
