Hi all !
I very recently switched to FP Open +OpenGapps pico , and everything went fine except for one application : Snapchat .
I can’t log in, it tells me that I’m probably using an unofficial client, but I downloaded it from the play store, so it might be because of FP open. I wondered if one of you had the same problem.
I’m rooted, and I tried to deactivate it, but it didn’t have any effects
Cheers
The Snapchat app doesn’t like Xposed.
Uninstall Xposed, log into Snapchat and re-install Xposed. (After you have logged in, Snapchat won’t complain about Xposed anymore.)
It worked ! many Thanks
