###Submit, find and vote for feature requests in the official bug-tracker:
You can find them under “Enhancements”:
Now, there is only a “Turn off” option.
Android has no built-in support for keeping the phone unlocked in a certain Wi-Fi.
The app “Smart Unlock” used for that stopped working with Android 6.0.
So Fairphone should create a built-in support for that.
This feature request has its own thread, where also alternative solutions are collected.
The cut, copy & paste controls brought with Android 6.0 are very inconvenient.
The old Android 5.1 controls were better. Also, they have a “select all” option missing in the new controls.
Smart unlock works, but it’s linked to connecting to a Bluetooth device, voice, or location. Google don’t offer an option for a specific WiFi so this isn’t a feature that can be supported
Reboot option is logged as a bug already
#Bring back the FP specific #features
AFAIK the plan is to release the (code of the) old launcher, lockscreen (widget, mood changer too?), … so the community can maintain them as Apps e.g. on F-Droid.
I just post this here as a little reminder.
I’d like the feature to disable the search bar and the most used apps in the app drawer
I know you can at least disable the most recent apps in the standard Google launcher, but I didn’t find the same functionality here.
Bring back “Flight mode
” option when you long press the power button
