FP 3 troubles connecting to 5ghz wifi
Hey there
FP 3 has issues connecting to 5ghz wifi networks.
Before the last update last week i had the opportunity to switch 5ghz network connecting off via the FP3 wifi settings. That way i always had a stable connection via 2.4ghz wifis.
Since the update last week the option to switch 5ghz connections off is nowhere to be found and the FP3 is connecting with 5ghz networks again. This causes a lot of connectivity issues.
How do i switch off 5ghz networks with the new update?
Thanks for your help
Adrian
A post was merged into an existing topic: Software Update: Android 11 for Fairphone 3 and 3+
