I still have it and I can send it to new zealand!
Hi.
Is the Top-module still available?
Yes, the top module is available.
UPDATE
I’m offering various pieces for FP3 (motherboard down after 3 years of good use. everything worked still perfectly) :
brand new (never used)
- battery
bottom module(went to Sweden)
used (3 years old; still working perfectly before motherboard went down):
- battery
bottom module(went to New Zealand)screen (few scratches) - used (3 years)(stayed in Brussels)camera module(went to the UK)top module(went to Tanzania)rear module(went to UK)- speaker module
every pieces you should seem valuable for you ! (A dozen Screws went to The Netherlands)
I have also a green protective case
Best regards,
Is it this kind of case? How much do you want including a cheap P&P to germany?
Yes, it is. I have the green one.
How much is it including a cheap P&P to germany?
Are the back cover and the bumper in OK condition?
And would you be willing to send them to Denmark?
If so, I would probably like to buy them…
Everything is still in good condition!
We can arrange in PM
Best regards,
Actually, would you give me the straight, larger connector band? I’m in Brussels
Update I still have:
- speaker module
- bumper
- back cover
I gave the batteries and connector bands to @angels_brussels.
