FP 3 sold for pieces (motherboard down)
[UPDATED 2 June 21:13]
I’m offering various pieces for FP3 (motherboard down after 3 years of good use. everything worked still perfectly) :
brand new (never used)
  • battery
  • bottom module
used (3 years old; still working perfectly before motherboard went down):
  • battery
  • bottom module
  • screen (few scratches) - used (3 years)
  • camera module
  • top module
    every pieces you should seem valuable for you !
I have also a green protective case
Best regards,
Hi there,
I’m interested in the battery and the bottom module, although I’m waiting for an answer of fairphone support to know whether the reparison is worth or not.
Would be happy if you contacted me with more information on the purchase!
Best,
Teresa
I’m in Belgium (Brussels).
Pick up or sending it by post.
Sebastien,
you may save me… My FP3 screen was slowly dying, now it is the end of it. It unglued, started to flicker, is totally unresponsive now.
And I just saw your post. I live in Brussels too.
Is your screen still available?
Thibaut
The spirit of the Fairphone community. Used screen picked up this morning from @sebastienp , and set on my otherwise dying phone.
My FP3 is running again!
Thanks! :pray::+1:
UPDATE (because I cannot edit)
  • battery
  • bottom module
  • battery
  • bottom module
  • camera module
  • top module
  • rear module
Best regards,
If you can unscrew the 2 Torx screws, you could also separate the motherboard from the rear module – there might be interest for that one, too.
It’s wonderful : parts of my FairPhone3 are now in Sweden, The Netherlands and Belgium.
It’s a pity I couldn’t find a way to send a battery to UK or Germany. I look at BPost (belgian post, it seems impossible) ; I look at UPS, it’s possible but limited to companies ?
If you know some ways, I’d be happy to learn them !
I’d recommend not breaking your head about shipping the battery abroad. Put an attractive price tag on it and offer it within Belgium. Or consider donating it to a Fairphone Angel in Belgium – i.e. either @angels_brussels or @angels_ghent.
