My FP3 is having problems loading.
The battery is not charged overnight and meanwhile cer is empty.
When I plug the phone in, the red light flashes three times and the phone vibrates briefly.
Then the screen shows “FAIRPHONE” and then “1% charge, please do not unplug”.
This has been going on for quite a long time. I have taken the battery out of the phone for some time and used different cables.
Noting you have used other cables but not if you have tried a new charger.
Another issue maybe dirt in the usb port which may be difficult to see and may be a thin coating on the pins causing resitance.
Please contact Fairphone a soon as possible to be on the safe side as it may be a module fault. You have a warranty for 2 years
Yes, it’s an issue with translation.
“Cer” does not make sence.
The Battery is empty now.
Yes, I read a lot of other posts.
I think, the special with my case ist the circle of “Blinking red light and Vibration, Boot-Screen, Loading screen with 1%”
