English
✏ FP 2/3/... Modules & Wishlist
design
wiki
fp3
hardwareupgrade
Tags: #<Tag:0x00007f57d42a3630> #<Tag:0x00007f57d42a34f0> #<Tag:0x00007f57d42a32c0> #<Tag:0x00007f57d42a3180>
#196
What kind of potential use-cases do you have in mind?
#197
I liked the concept of my old LG g3 a lot, which had such buttons on the back and so I thought why not make a small PCB with those abilities + some extra pads for other stuff to tinker :slight_smile:
#198
let out your inner nerd… :smiley:
#199
Hi.
It would be nice to improve the loud speaker and make it more loud. The current maximum volume is not really loud and not efficient in noisy environment.
The value in /etc/mixer_paths.xml is 87 by default. I tried to increase it to 92 but the sound quality is lower. So I guess it’s a hardware limitation.
#200
I’d wish for them to port new chipsets to the phone and different displays like 18:9 display etc to make it more interesting for the consumer to make their own phone. Then if I wanted to make my phone have better chipset or better display , I could buy the latest module instead of buying a new phone for instance. IF such a thing is implemented, I will buy the phone instantly!
#201
Different displays is hard I think… I mean the size of the display is pretty much the size of the hole device … different resolutions would be possible… for me the fairphone is allright :slight_smile: not perfect but for now I couldn`t wish more :slight_smile:
#202
About the covers, the original transparent one was looking really great, showing what makes FairPhone so special.
Such a pity that those covers were not strong enough.
Is there any chance to do the “slim” covers with a transparent material ? Would be great.
#203
Many have asked - only one has delivered so far:
#204
I don’t understand. Do you mean that they are working on it and delivered only one cover to someone who asked ? Those pictures are showing something about 3D printing. Is that a partner of FairPhone ?
#205
No I meant many have asked the same question as you. Only one person did something about it.
#206
And how about the FairPhone company ? Is there something in their plan if so many people asked already ?
#207
Only they can give you an answer to that question.
https://www.fairphone.com/en/about/contact-us/
#208
Thanks. Just contacted them and already got a reply !
Fairphone 3 - Interview of Bas from FrAndroid
First 3d printed transparent Slim Cover
FairPhone 2 - Next New Camera? (Discussion about curiosity and desire)
#209
In another thread a bottom module for FP2 with USB-C was asked for, and it’s included above in the wish list. Now that the new camera modules are shipping - is this the next step?
I’m quite fond of the new USB cable standard and even though it won’t change anything but the physical layout I’d like the next bottom module I replace the current one with after it’s worn out to have USB-C.:slight_smile:
#210
A few new PCBs I´m currently working on :slight_smile:
They will be used as addons for the DIY-shield and add different possibilities to your FP2. :slight_smile:
#1: Adds a microphone (easier to use than the internal) and a few Neopixels to visualize sound:
#2: Adds an OLED which could be used for example to display the number of messages or calls or whatever
#3: Adds a charlieplexed LED matrix with 15 x 7 LEDs
what do you thing ?
any ideas for addon-boards or complete extension boards?
#211
You love your Fairphone? Me too!!
Show your LOVE :stuck_out_tongue:
#212
Speaking of USB ports: for the next model, I really would like the headphone jack and the USB port to be on the same side.
Using headphones while also charging the phone with a battery pack makes it almost impossible to carry the phone in my coat pocket, not to mention inherently hardware damaging.
#213
  • three SIM based
  • One SIM is cryto-proceted
  • Firefox-OS based
  • Taking Firefox-OS in dev. for future mobile devices
All the BEST!
Bruno Ballack
#215
Push NFC for enable using AndroidBeam for fast sharing data with friends^^lg
#216
maybe this is already solved for the actual fp2 models - but it would be great if the sim slots could easily be repaired/exchanged. in the first fp2 models this seems not to be possible, if one of the two slots gets broken.
