Hi, I’m looking for a camera module for the FP 1. I live in Southern Germany. Would 20€ be reasonable, considering the camera would be used? If not, please make suggestions. Thanks!
Comments are closed on this topic. If interested, please contact me in a personal message.
Although you can click on it in the shop, it then says it’s out of stock, since FP 1 is no longer supported. Or am I missing something? I would be grateful for a link!
You can add it to the basket and continue with an order. Click on my blue words above and scroll down a bit there. I think the “End of Stock” note is just a general insertion indicating that Fairphone will not re-stock sold out spares.
It helps to press down the camera with a pen when lifting the motherboard from the display. This way the camera simply stays glued to the display and you can remove it more easily.
