Hi everyone
How do I forward calls on my fairphone (2:nd generation)? Greatful if someone could help me with that.
I think this is what you are looking for:
- Go to the Phone dialler app
- Press the settings button (bottom left button on your phone)
- Select the option called Settings
- Choose Voice Call
- Choose Call Forwarding
- Select your SIM (if you have 2 installed)
- You will now get a list of forwarding scenarios which you can change which should be picked up from your network operator
Thank you Chris, not even my digital son found this. Thanks again!/Mikael
No problem, glad this was the solution
This topic is now closed. New replies are no longer allowed.
