Forum shortcuts and Formatting Language
Writing a new post I stumbled upon the Shortcut “Ctrl+g”, which opens the image uploader.
So I did a quick research and found this list: https://meta.discourse.org/t/keyboard-shortcuts/1589
Maybe it is useful for some of you! :slight_smile:
Edit: BBCode [key] doesn’t work on the FP forum…
There is a list of shortcuts on the forum already. It’s on the menu by your avatar :smiley_cat:
@Chris_R OOPS, Sorry, didn’t notice that one… :blush: Good to know, though.
But: The one I stumbled upon doesn’t seem to be on there… :wink: Anyways, is there a list of BBCodes too?
Thanks for the fast answer, btw! :slight_smile:
There is no official list of BBCode or Markdown Syntax that works on this forum, however most of them do.
Just play around a bit :slight_smile: BBCode however seems to be as in CSS/HTML, with “< ></ >” instead of “[ ] [/]” . There are a couples that don’t work here, but work on the official forums of Discourse, for example “Spoilers”.
List of Markdown syntax: https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet
These all seem to work as well: http://www-bdnew.fnal.gov/pbar/htmlref.html
Some examples from the last link:
3 x 108
H2O
Deleted Text
These seem to have problems with quoting though… Anyways I will try some when I need them.
The problem was just that I did not know the exact syntax of quoting, since quoting does not work in a mobile browser (and I wanted to use it on the go). Also I am not very familiar with the formatting languages out there… :frowning:
EDIT: [quote=“John F. Kennedy (1917 - 1963)”]Mothers may still want their sons to grow up to be President, but according to a famous Gallup poll of some years ago, some 73 percent do not want them to become politicians in the process.[/quote]
Hey you can even insert any name in a quote! :slight_smile:
