I just got my new fairphone 2 and after looking to it I’m seeing that the screen flash a little bit. You don’t see it unless you really look at it. But it really give head pain if you are looking at it for 20min. Could some of you indicate me the source of the problem?
Does this happen at low-brightness? Then it’s a known bug and the workaround is: Disable auto-brightness and set the brightness to higher than minimum.
https://forum.fairphone.com/t/screen-flickers-at-low-brightness/11577?u=paulakreuzer&source_topic_id=14335Somethimes also on higher brightness, but without the adaptive brightness its gone. Thank you.
