probably a false move on my part:
-when the updated Open .16.06 to 16.07 seems to have set an application TWRP
-since I can not do anything because I do not understand this App
-and more, it seems impossible to uninstall
-in fact I have desired to re-install Open from 16.06 for updating the GPS stops working …
How to get out of this impasse?
Thank you
Thank You…
But could you explain how to use this TWRP to intall OPEN 16.06…
I tried but I tried to open fp2-sibon-16.06-… zip with Updater and… ???
Keep cool…
Thanks
Nano
Thank you for your help…
I try an other solution which seems efficient…
1-Updater OPEN 16.07.1 to OS 1.5.1
2-Updater OS 1.5.1. to OS 1.4.1
3-Updater OS 1.4.1 to OPEN 16.06…0
TWRP disapears at step 1…
I checked all the directories and I did not find any directory TWRP ? (like before with OPEN 16.07.1)
It’s do-it yourself but I’very happy with that and I’ll stop all the OS open updates…
An other good new : the GPS is OK with OPEN 16.06.0 (like before)
Ouf…
Thanks
Nano
Hello again
I think I was clear with regard to my questions about TWRP that had “spoil my life” as its operation is incomprehensible … I expect from Fairphone:
-1- An explanation for using TWRP
-2-Why TWRP not seem to be installed in OS 16.06.0 (not found directory)
Finally, it seems desirable to me that Fairphone understands that its customers are not necessarily specialists of Android but still possess a brain and would understand …
I think it is a great recovery, way better than the default Android recovery, Not only in functionality, but it also comes with a nice and intuitive GUI, so personally I am very happy they replaced the default recovery with TWRP for the Open OS. In my opinion one of the major advantages over the FP OS.
