Fingerprint setting missing after recent update
Since the latest update I cannot use the fingerprint anymore to unlock my phone or any applications. The option doesn’t exist any more in the settings.
The only available biometric option is facial recognition.
Is there any way to reverse the update or any hope that the fingerprint unlocking will be back at some point ?
Did you try to reboot?
Did you check the fingerprint reader status in the hardware check function?
I assume the update is rather a coincidence
I’m sorry for not getting back earlier.
Everything works fine after rebooting my phone
Thank you very much :slight_smile:
