Fingerprint sensor cable
I made the mistake of prematurely screwing in one of the main two screws on the back of the phone before putting on the back case, I realised straight away and unscrewed it but it was too late, they designed this phone so the fingerprint sensor ribbon cable runs directly over the back of it.
It drove me insane for weeks not having fingerprint capability and kapton or eletrical tape did not fix it either. I couldn’t see a replacement cable anywhere so I spent another $1100 aud on a whole new fairphone 6… I figured it’s a good company and it will be great to have spare parts, well guess what, it happened again.
I’m 2 grand in the hole, I know this was my fault but I can’t comprehend why they have designed it in this way. Does anyone know how I can fix or replace this cable?
I’m In Australia so was unable to purchase from official fairphone site, just from amazon so would rather just fix it as opposed to sending it to Europe or wherever the store is that sold me this.
hello
I do not have FP6 so it took me a bit to follow your description.
Am I correct in assuming it is this part of the frame?
and we are talking about putting the screw literally through the frame?
If that is correct, mainboard is indeed not for sale separately.
For more information on FP6 schematics, you may consult this document
and for out-of-warranty price list
https://support.fairphone.com/hc/en-us/articles/37450191748370-Out-of-warranty-repair-costs-for-The-Fairphone-Gen-6
Hello, your screenshot is correct. That is the part of the frame with the LCD removed.
I do find it it funny though… Fairphone makes a phone with a main flex cable running directly across the underside of a screw which if screwed in 1mm too deep then the entire frame needs replacing which like you said… Is not sold separately.
God knows how many people have sent their phone in for repair without knowing why their fingerprint sensor doesn’t work.
I’m so disappointed.
I just watched the official screen replacement guide for the FP6 and they suggested 2 containers to store the screws while disassembling. I would rather use 3-4 containers and put each part and its screws in a separate container, so that screwing in this screw prematurely is much harder.
Did you contact the Fairphone Support to ask for help/advice, if/how this can be fixed and to help them make people aware of this design flaw and maybe fix it in the next production batch?
Fairphone state that because I purchased from a reseller and am in Australia, I need to send back to the reseller, which I’ve been struggling to work out how to do via Amazon.
Good point regarding making them aware to rectify the issue. I will let them know exactly how this happened.
I don’t think I’m willing to buy a third Fairphone so fingers crossed I can get in touch with this reseller.
