For month my husbands phone is declining. The display shows a fibrating image , or stripes, or turns grey. After a while the usual display slowly appears or when shutting of slowly, to slow, disappears.
Today nothing appears. But the introduction animation ‘fairphone’ does show in bright letters although the screen turns grey before the anatoom is completed.
Now I don’t know whether the problem is the screen (which can be replaced) or the motherboard itself???
Please check the status of the SD card if you have one to see if it formatted as Internal or Potable.
Also check the amount of memory left, you will need at least 6GB
You may also want to clear the cache for various apps, phone, camera, gallery etc.
If none of the above help you may like to try starting in safe mode.
Failing that there is always the option of a factory reset, but that will wipe all your data and you will then have to proceed as though it is a new phone
If you’re lucky, there may be a #fairphoneangel in your area that would have a FP3 display they would agree to let you test to check if it solves the problem (or perhaps you know someone else with a FP3 that could help you).
Auch! and thanks!
It seems to me, we have them for so long already. I checked with the screen of my own device, it is the screen that’s failing. And that is pretty fast as we bought it in december 2019.
