I am pretty much in the same situation as Jo_na
( I bricked my FP3 and i hated it).
But the solution ( Fairphone 3 unlocking without oem unlocking) does not quite work for me.
with much of research in between the steps I did:
1.) updated to Android 10, in the settings of the preinstalled rom.
2.) installed Magisk and then TWRP apk, because Magisk couldn’t root from the app und I know about the work-around through flashing the Magisk.zip with TWRP
3.)unlock the oem by (/en/bootloader-unlocking-code-for-fairphone-3/) and (/hc/en-us/articles/360048646311-Manage-the-bootloader-of-your-FP3-FP3-) bulletin 1 to 3
4.)use fastboot to boot with TWRP, flash Magisk and then TWRP
5.)worked like a charm
6.)following the warning while booting, I locked the oem again (/en/bootloader-unlocking-code-for-fairphone-3/) and (/hc/en-us/articles/360048646311-Manage-the-bootloader-of-your-FP3-FP3-) point 4:
" fastboot oem lock"
7.)got the corruption warning, and the get stock in fastboot, cannot go to recovery or normal boot.
7.1)send an email to the Fairphone-support
8.) tried myself " fastboot oem unlock" and [Fairphone 3 unlocking without oem unlocking] which both unlocked the oem again BUT still cannot boot to TWRP using fastboot
user@linux$ fastboot boot twrp-3.4.0-0-FP3.img
downloading ‘boot.img’…
OKAY [ 0.793s]
booting…
FAILED (remote: unknown reason)
finished. total time: 2.171s
also tried:
user@linux$ sudo fastboot boot twrp-3.4.0-0-FP3.img
[sudo] password for jan:
OKAY [ 0.765s]
booting…
finished. total time: 2.165s
and
user@linux$ fastboot flash boot twrp-3.4.0-0-FP3.img
target reported max download size of 534773760 bytes
sending ‘boot’ (29486 KB)…
OKAY [ 0.793s]
writing ‘boot’…
FAILED (remote: partition table doesn’t exist)
finished. total time: 0.810s
I am no Android expert, just want root to run Titanium Backup again and freeze some annoying goggle apps.
sigh, if I just didn’t lock the oem…
Any help is appreciated.
ps. sorry, as a new user I can only write 2 links in a post, so I deleted the domain so the text isn’t recognized as a link.
EDIT:
I also tried to flash the stock rom with fastboot. [TWRP installable stock firmware packages for Fairphone 3]
using:
user@linux$ fastboot update Fairphone_FP3_8901.2.A.0110.20200109_01092024_user_release-keys_2.zip
archive does not contain ‘android-info.txt’
error: update package ‘Fairphone_FP3_8901.2.A.0110.20200109_01092024_user_release-keys_2.zip’ has no android-info.txt
EDIT2:
user@linux$ fastboot getvar all
(bootloader) version:0.5
(bootloader) hw-chip:SDM632
(bootloader) battery-soc-ok:yes
(bootloader) battery-voltage:4295443
(bootloader) variant:MTP eMMC
(bootloader) unlocked:yes
(bootloader) secure:no
(bootloader) version-baseband:
(bootloader) version-bootloader:
(bootloader) logical-block-size:0x200
(bootloader) erase-block-size:0x200
(bootloader) display-panel:
(bootloader) off-mode-charge:1
(bootloader) adb-enabled:0
(bootloader) charger-screen-enabled:1
(bootloader) max-download-size: 0x1fe00000
(bootloader) slot-count:2
(bootloader) current-slot:INVALID
(bootloader) slot-retry-count:b:0
(bootloader) slot-success:b:No
(bootloader) slot-active:b:No
(bootloader) slot-unbootable:b:Yes
(bootloader) slot-retry-count:a:7
(bootloader) slot-success:a:No
(bootloader) slot-active:a:No
(bootloader) slot-unbootable:a:No
(bootloader) has-slot:userdata: No
(bootloader) has-slot:product: Yes
(bootloader) has-slot:frp: No
(bootloader) has-slot:logdump: No
(bootloader) has-slot:dpo: No
(bootloader) has-slot:msadp: No
(bootloader) has-slot:apdp: No
(bootloader) has-slot:keymaster: Yes
(bootloader) has-slot:cmnlib64: Yes
(bootloader) has-slot:cmnlib: Yes
(bootloader) has-slot:lksecapp: Yes
(bootloader) has-slot:mcfg: No
(bootloader) has-slot:syscfg: No
(bootloader) has-slot:mdtp: Yes
(bootloader) has-slot:dip: No
(bootloader) has-slot:mota: No
(bootloader) has-slot:limits: No
(bootloader) has-slot:oem: No
(bootloader) has-slot:config: No
(bootloader) has-slot:prodinfo: No
(bootloader) has-slot:keystore: No
(bootloader) has-slot:misc: No
(bootloader) has-slot:persist: No
(bootloader) has-slot:vendor: Yes
(bootloader) has-slot:system: Yes
(bootloader) has-slot:devinfo: No
(bootloader) has-slot:boot: Yes
(bootloader) has-slot:vbmeta: Yes
(bootloader) has-slot:dtbo: Yes
(bootloader) has-slot:aboot: Yes
(bootloader) has-slot:splash: No
(bootloader) has-slot:sec: No
(bootloader) has-slot:fsg: No
(bootloader) has-slot:DDR: No
(bootloader) has-slot:modemst2: No
(bootloader) has-slot:modemst1: No
(bootloader) has-slot:dsp: Yes
(bootloader) has-slot:devcfg: Yes
(bootloader) has-slot:tz: Yes
(bootloader) has-slot:rpm: Yes
(bootloader) has-slot:sbl1: Yes
(bootloader) has-slot:ssd: No
(bootloader) has-slot:fsc: No
(bootloader) has-slot:modem: Yes
(bootloader) partition-type:userdata:ext4
(bootloader) partition-size:userdata: 0xc2f6f9e00
(bootloader) partition-type:product_b:raw
(bootloader) partition-size:product_b: 0x8000000
(bootloader) partition-type:product_a:raw
(bootloader) partition-size:product_a: 0x8000000
(bootloader) partition-type:frp:raw
(bootloader) partition-size:frp: 0x80000
(bootloader) partition-type:logdump:raw
(bootloader) partition-size:logdump: 0x4000000
(bootloader) partition-type:dpo:raw
(bootloader) partition-size:dpo: 0x2000
(bootloader) partition-type:msadp:raw
(bootloader) partition-size:msadp: 0x40000
(bootloader) partition-type:apdp:raw
(bootloader) partition-size:apdp: 0x40000
(bootloader) partition-type:keymaster_b:raw
(bootloader) partition-size:keymaster_b: 0x100000
(bootloader) partition-type:keymaster_a:raw
(bootloader) partition-size:keymaster_a: 0x100000
(bootloader) partition-type:cmnlib64_b:raw
(bootloader) partition-size:cmnlib64_b: 0x100000
(bootloader) partition-type:cmnlib64_a:raw
(bootloader) partition-size:cmnlib64_a: 0x100000
(bootloader) partition-type:cmnlib_b:raw
(bootloader) partition-size:cmnlib_b: 0x100000
(bootloader) partition-type:cmnlib_a:raw
(bootloader) partition-size:cmnlib_a: 0x100000
(bootloader) partition-type:lksecapp_b:raw
(bootloader) partition-size:lksecapp_b: 0x20000
(bootloader) partition-type:lksecapp_a:raw
(bootloader) partition-size:lksecapp_a: 0x20000
(bootloader) partition-type:mcfg:raw
(bootloader) partition-size:mcfg: 0x400000
(bootloader) partition-type:syscfg:raw
(bootloader) partition-size:syscfg: 0x80000
(bootloader) partition-type:mdtp_b:raw
(bootloader) partition-size:mdtp_b: 0x2000000
(bootloader) partition-type:mdtp_a:raw
(bootloader) partition-size:mdtp_a: 0x2000000
(bootloader) partition-type:dip:raw
(bootloader) partition-size:dip: 0x100000
(bootloader) partition-type:mota:raw
(bootloader) partition-size:mota: 0x80000
(bootloader) partition-type:limits:raw
(bootloader) partition-size:limits: 0x8000
(bootloader) partition-type:oem:raw
(bootloader) partition-size:oem: 0x10000000
(bootloader) partition-type:config:raw
(bootloader) partition-size:config: 0x8000
(bootloader) partition-type:prodinfo:raw
(bootloader) partition-size:prodinfo: 0x200000
(bootloader) partition-type:keystore:raw
(bootloader) partition-size:keystore: 0x80000
(bootloader) partition-type:misc:raw
(bootloader) partition-size:misc: 0x100000
(bootloader) partition-type:persist:raw
(bootloader) partition-size:persist: 0x2000000
(bootloader) partition-type:vendor_b:raw
(bootloader) partition-size:vendor_b: 0x40000000
(bootloader) partition-type:vendor_a:raw
(bootloader) partition-size:vendor_a: 0x40000000
(bootloader) partition-type:system_b:raw
(bootloader) partition-size:system_b: 0xc0000000
(bootloader) partition-type:system_a:raw
(bootloader) partition-size:system_a: 0xc0000000
(bootloader) partition-type:devinfo:raw
(bootloader) partition-size:devinfo: 0x100000
(bootloader) partition-type:boot_b:raw
(bootloader) partition-size:boot_b: 0x4000000
(bootloader) partition-type:boot_a:raw
(bootloader) partition-size:boot_a: 0x4000000
(bootloader) partition-type:vbmeta_b:raw
(bootloader) partition-size:vbmeta_b: 0x10000
(bootloader) partition-type:vbmeta_a:raw
(bootloader) partition-size:vbmeta_a: 0x10000
(bootloader) partition-type:dtbo_b:raw
(bootloader) partition-size:dtbo_b: 0x800000
(bootloader) partition-type:dtbo_a:raw
(bootloader) partition-size:dtbo_a: 0x800000
(bootloader) partition-type:aboot_b:raw
(bootloader) partition-size:aboot_b: 0x300000
(bootloader) partition-type:aboot_a:raw
(bootloader) partition-size:aboot_a: 0x300000
(bootloader) partition-type:splash:raw
(bootloader) partition-size:splash: 0xb00000
(bootloader) partition-type:sec:raw
(bootloader) partition-size:sec: 0x4000
(bootloader) partition-type:fsg:raw
(bootloader) partition-size:fsg: 0x180000
(bootloader) partition-type:DDR:raw
(bootloader) partition-size:DDR: 0x8000
(bootloader) partition-type:modemst2:raw
(bootloader) partition-size:modemst2: 0x180000
(bootloader) partition-type:modemst1:raw
(bootloader) partition-size:modemst1: 0x180000
(bootloader) partition-type:dsp_b:raw
(bootloader) partition-size:dsp_b: 0x1000000
(bootloader) partition-type:dsp_a:raw
(bootloader) partition-size:dsp_a: 0x1000000
(bootloader) partition-type:devcfg_b:raw
(bootloader) partition-size:devcfg_b: 0x40000
(bootloader) partition-type:devcfg_a:raw
(bootloader) partition-size:devcfg_a: 0x40000
(bootloader) partition-type:tz_b:raw
(bootloader) partition-size:tz_b: 0x200000
(bootloader) partition-type:tz_a:raw
(bootloader) partition-size:tz_a: 0x200000
(bootloader) partition-type:rpm_b:raw
(bootloader) partition-size:rpm_b: 0x80000
(bootloader) partition-type:rpm_a:raw
(bootloader) partition-size:rpm_a: 0x80000
(bootloader) partition-type:sbl1_b:raw
(bootloader) partition-size:sbl1_b: 0x80000
(bootloader) partition-type:sbl1_a:raw
(bootloader) partition-size:sbl1_a: 0x80000
(bootloader) partition-type:ssd:raw
(bootloader) partition-size:ssd: 0x2000
(bootloader) partition-type:fsc:raw
(bootloader) partition-size:fsc: 0x400
(bootloader) partition-type:modem_b:raw
(bootloader) partition-size:modem_b: 0x5800000
(bootloader) partition-type:modem_a:raw
(bootloader) partition-size:modem_a: 0x5800000
(bootloader) hw-revision:10000
(bootloader) serialno:A209JDY40201
(bootloader) kernel:lk
(bootloader) product:FP3
all:
finished. total time: 2.000s
