My first impression of this wrapper is very convincing. The working speed also seems to me significantly higher than that of running maps in the browser.
If anyone is looking for a good and very high quality bike mount for his FP4, here is my recommendation:
Very high quality, stable and accurate fit for the quite thick FP4.
Nothing wobbles, despite the fact that the FP is quite heavy.
Completely made of aluminum and stainless steel screws.
Hab noch so ein parr /e/ Aufkleber gefunden…Brauch ich nicht → Sind weg!
Wer will, soll mir ne PM mit postalischer Anschrift schicken. Ich sende sie dann per Brief zu.
Kost nix, auch an den 85 Cent Porto werd ich nicht sterben
If somebody having trouble with geo-restricted apps in aurora store.
(search for a specific app, but it will not be found…I had this problem with satellite VoIP app from sipgate. After this fix, the app could be found and installed)
aurora store geo-restricted:
Change everything to your language and country instead of german/germany
Geo-Restriction of auror store apps:
Language set to German
Settings | System | Languages & Input.
In Aurora Store
In Spoof manager, set Language to German
In Settings | Networking, set the ‘Insecure anonymous session’ switch to ‘On’
Log out if you had already logged in
Stop the app (using the task manager)
Restart the app
Log in as Anonymous
After you’ve done all this, the Nationwide Banking App should be top of the list when you search for. You should also be able to install other German specific geo-restricted apps, like satellite VoIP app from sipgate.
