Fairphone stops charging when camera is in use
My new Fairphone 2 stops charging when either of the two cameras is in use. I have tested this out in various ways and confirmed that it does not depend on the app that uses the camera. It’s not a major issue as far as I’m concerned, as soon as I stop using the camera, charging continues. Still, it is annoying. I just wanted to know: Is this a known issue? Is there a known fix for this?
I’ve heard of this issue before but can’t find any posts atm - but the right place for this is the #bugtracker anyway. Search there if a report already exists and if not create a report with minor priority.
This issue is currently being investigated.
https://bugtracker.fairphone.com/project/fairphone-fairphone-os-android-6/issue/98
Thanks for the reply, hope this gets resolved soon
