Fairphone no longer being recognised as removable storage device
Dear all,
I encounter the problem that my Fairphone FP1U is no longer recognised as a removable storage device on my Ubuntu Linux 15.10 desktop.
I ensured that USB debugging is enabled under Developer options.
Could someone advise me please how to proceed with this problem?
Thankfully,
~Robert
USB Debugging should not make any difference (only if you want to use adb).
Is there a notification in the status bar when you connect to your computer? If yes, click it and it will give you several connection options (only charging/MTP/PTP/USB mass storage. You need to choose MTP.)
Sometimes there is no notification at all but still try swiping down the status bar and have a look.
Dear all,
Thank you for all your support!
It turned out that it was not a problem of my phone, nor of my Ubuntu Linux but the cable.
I used a split cable which could charge my phone but did not allow it to be recognised as a removable storage. I have no clue as to why. A conventional cable does work perfectly.
Thankfully,
~Robert
