Unlike yourself, I do use it - when hiking in remote locations, its a great backup as you can reference the coordinates on an OS map. And i’ve used it for field surveying too - which I’d especially like to be able to do with this phone. So it is a bit disappointing.
I think I’ll start a separate post actually re: the GPS.
New topic about GPS issues where you can continue the discussion on the GPS issues and potential fixes and workarounds. Thanks @nick for starting this topic.
Hi @wjvdv, since not many people have commented on your disappointment regarding the camera, I thought I’d chip in. Yes, there’s a big difference between my Canon DSLR and the Fairphone camera… and yes, the lack of contrast can be annoying. However, there are several things that can lead to better results:
It really needs plenty of light to do its work properly.
I’ve been using the Camera Awesome app instead of the stock camera, which has improved my experience - it gives you more control, and I find the ability to use the volume buttons as the shutter button very useful - just feels more natural / like a ‘real camera’.
The stock gallery gives a wide variety of editing options. Playing around with the curves often helps to get better contrast. After the fact, I know…
Here’s a photo that I’ve taken with the phone a few weeks ago:
Yes, what @Emma said. No matter how high you push pixel count, a mobile phone camera can never be a DSLR. Mind you, the OP’s description sounds more like a broken phone than a simple dislike of the camera.
That said, it’s always well worth experimenting with camera apps, as the default Android camera doesn’t always exploit the full capabilities of the camera hardware. I did a quick comparison with 3 apps I’ve used before, and sharpness varied quite a lot. The quite basic Camera ICS+ has much more accurate auto-focus than the default app, whereas the more feature-rich Camera ZOOM produced disappointingly soft images.
My connectivity problem wasn’t really solved with hard reset. I it was mainly optimism, after I while I realised that it was as bad as before.
Finally I dissembled It and found out that the antenna cable wasn’t properly connected.
It was probably I that hadn’t connect it properly after another time when I had to dissemble it to dry after it went down in the water in a stream, when hiking.
I was wondering have any of your expectations been improved? (perhaps you had a fault phone?)
I am thinking of buying a fairphone because I love the concept but I sure do want to get a phone that meets expectations of its asking price.
I used to have a samsung S2, the camera worked great on it, I wouldn’t compare it to a DSLR like other people mentioned below but I would expect a phone of this price to take decent photos all the same.
GPS is also important to me and should ‘just work’
Actually the answer is: no. It seems nothing has changed after I received the phone back from the support center.
However I would advise you to buy the FairPhone anyway. If you buy it now, you won’t get the first batch phone and according to all reactions here, the newer batches don’t have the problems that occurred to me.
